Volume enclosed by a spherical coordinate surface
The discussion focuses on calculating the volume enclosed by the spherical coordinate surface defined by ρ = 2sin(φ). The integral setup is confirmed as dV = ∫∫∫(ρ^2)sin(φ)dρdφdθ with limits of integration for ρ from 0 to 2sin(φ), φ from 0 to π, and θ from 0 to 2π. The final volume calculation yields 2π² after resolving the integral of sin⁴(φ) using trigonometric identities and substitutions. Participants clarify the integration process and confirm the correctness of the final answer.
  • Spherical coordinates and their applications
  • Triple integrals in calculus
  • Trigonometric identities and substitutions
  • Volume calculation techniques in multivariable calculus
  • Study spherical coordinate transformations in calculus
  • Learn advanced integration techniques, including trigonometric substitutions
  • Explore volume calculations using triple integrals in various coordinate systems
  • Review the properties of sin⁴(φ) and related integrals in calculus
Students and educators in mathematics, particularly those focusing on calculus and multivariable integration, as well as anyone interested in understanding spherical coordinates and volume calculations.
forestmine
Find the volume enclosed by the spherical coordinate surface ρ = 2sin∅
dV = ∫∫∫(ρ^2)sin∅dρd∅dθ
(Sorry about my notation!)
Alright, here's what I've done so far...
Since the region is a torus, centered around the z-axis, I began by finding my limits of integration for ρ, which I think would simply be from 0 to 2sin∅.
For my limits for ∅, I started at the utmost point on the positive z-axis, which I believe is 0 in regards to ∅, and it covers the entire ∅ "region" down to the negative z axis, so the limits are 0 to pi.
And for θ, I got simply 0 to 2pi.
Given those limits, integrating ((ρ^2)sin∅)dρd∅dθ, I wind up with 0, which on the one hand, I've convinced myself makes sense, since it is a torus, and it is symmetrical about the axes (like saying the area under the cosine from 0 to 2pi is 0). On the other hand, a volume of 0 for a physical object simply doesn't make sense.
I have a feeling I'm simply going about the limits wrong. If I've got those right, I'll post my integration work in case someone can spot the problem.
Thanks guys!
So what you are saying is that your integral is
\int_{\theta= 0}^{2\pi}\int_{\phi= 0}^\pi\int_{\rho= 0}^{2\sin(\phi)} \rho^2sin(\phi) d\rho d\phi d\theta
Clearly, the \theta integral gives a factor or 2\pi. Also, the integral of \rho^2 is (1/3)\rho^3 so, evaluating that integral we have
\frac{16}{3}\int_0^\pi sin^4(\phi)d\phi
I do not get 0 when I integrate that.
Ok, so as far as my limits of integration go, those are ok?
I also get (1/3)\rho^3, and evaluating at 2sin\phi I get 8/3∫∫sin^4(\phi) d\phid\theta. I'm not sure where I ought to be getting 16 from?
As for ∫∫sin^4(\phi) d\phid\theta, I think I'm simply screwing up some basic calculus. I said that integral of sin^4(\phi) is -cos^4((\phi). Should I be using some trig substitutions rather than making that leap?
Then I evaluated that from 0 to pi, which gives me -1 + 1, so I can't even make it to my dθ integral...
Thinking this is a trig substition I'm forgetting...
Yes, you should. Start by writing ##\sin^4\phi## as ##(\sin^2 \phi)^2## and using ##\sin^2\phi = \frac {1-\cos(2\phi)} 2##. Then after a little algebra you will need a double angle formula again...
Ok, so when I expand (1-cos(2\phi)/2)^2, I get 1/4 - (cos(2\phi))/2 + (cos^2(2\phi))/4
Replacing the last term with a half-angle formula, I have
1/4 - (cos(2\phi))/2 +1/8 + (cos(2\phi))/8
At that point, I take the integral of that with respect to \phi.
I wind up with 1/4*\phi - 1/2*sin(\phi)cos(\phi) + 1/8*\phi + 1/8*sin(\phi)cos(\phi).
Evaluating from 0 to pi, I wind up with:
1/4pi +1/8pi.
Integrate that with respect to \theta and evaluating from 0 to 2pi, I get
8/3(1/2*pi^2 + 1/4*pi^2)
where 8/3 was from the very first integration of \rho.
Hope this is easy enough to follow along in this format. If you could, let me know if the work looks ago.
Thanks so much by the way, I really appreciate it.
forestmine said:
I get
Hey, it isn't my job to simplify your answer. :smile: You simplify it, then I will tell you whether it agrees with mine.
Hehe fair enough. I get 2pi^2.
Looks like a nice and neat enough answer -- hopefully that's what you got!
I went through the problem a second time, though, and now I'm finding myself confused about one of the trig substitutions I made. Once I've expanded (1-cos(2ϕ)/2)^2, I'm left with a few terms + (cos^2(2ϕ))/4.
I know that cos^2(x) = (1 + cos(2x))/2. But since mine is essentially (2x), does it become 1+cos(4x)...or am I beginning to overthink this. I think I am...my 2x = x = theta in that trig sub, so I should be alright.
Oh jeez, this is my problem, haha. Over-thinking.
Yes, that's correct.
Thank you so much. I really appreciate all the help.
