Volume of Frozen Water: Effects on Water Level
  • Thread starter Thread starter mattakun
    Volume Water
When a quarter of water is frozen, the total volume of the system does not change significantly, as the ice will displace an equivalent volume of water. Although freezing water expands by about 9%, the portion of ice that floats (approximately 89.5% submerged) will displace a volume equal to the original water it replaced. Therefore, the water level remains constant, similar to how an ice cube in a glass does not change the water level when it melts. The debate centers on whether the water level will rise or drop, but the consensus is that it stays the same. Understanding the principles of buoyancy and displacement clarifies this phenomenon.
mattakun
Hello,
I have been having a debate with someone that is driving me insane...
Here is the problem
http://www.ra31v1.pwp.blueyonder.co.uk/water1.JPG
Lets say we have 20,000m^3 of water like the image above.
If we were to freeze a quarter of it. what will happen to the level of the water, eg, will it rise, drop or will it stay the same?
The information I have looked up states that on freezing water it expands by
9% and also that floating ice on water will be 89.5% underwater.
http://www.ra31v1.pwp.blueyonder.co.uk/water2.JPG
Here we have frozen a quarter which would then become...
http://www.ra31v1.pwp.blueyonder.co.uk/water3.JPG
with 89.5% underwater and 10.5% above the surface of the water.
so now I can say that 89.5% of 5450m^3 = 4877.75m^3 is under the surface of the water.
so now if you add the remaining 3 quarters of water 15,000m^3 to the frozen quarter that's underwater 4877.75m^3 you get:
15,000m^3 + 4877.75m^3 = 19877.75m^3 total
originally before freezing a quarter there was 20,000m^3, and now after freezing there is 19877.75m^3 so this must mean that the water level will drop slightly.
However, the person I am having a debate with seems to think differently, she believes that if you freeze a quarter like we have done the level of the water will not rise or fall, it will stay exactly the same.
PLEASE will someone clarify this.
Thanks very much
Do you have a reference for these values? They are not consistent. If you freeze a block of pure water such that it floats, it will displace a volume of water equal to its original volume. If the original volume is 1 unit, and it expands by 9% when frozen, it's new volume will be 1.09 units. 1/1.09 = 91.7% will be underwater.
She is correct. Just like an ice cube floating in a glass of water--when it melts, does the water level change?
mattakun said:
Hello,
Here is the problem
Thanks very much
Sorry
But your friend is correct.the ice cube floats ie a bit of it is outside water. Now definately the volume increases of the whole system but the amount by which the volume increases is exactly equal to the volume of ice outside water. now try to push the icecube in the water and definitely the water level would arise
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
