So, the conversion factor is 10^6.
  • Thread starter Thread starter Twilit_Truth
    Unit Volume
To convert from meters cubed to centimeters cubed, the conversion factor changes from 10^-2 to 10^6. This is because when cubing the conversion factor for linear measurements, you must cube both sides of the equation. Therefore, 1 meter equals 10^2 centimeters, and when cubed, it results in 1 cubic meter equaling 10^6 cubic centimeters. This highlights the significant difference in scale when dealing with volume conversions compared to linear measurements. Understanding this conversion is essential for accurate calculations in various applications.
Twilit_Truth
When going from meters cubed to centimeters cubed, what do you change from the normal 10 ^ -2?
Thank you for your time.
Just think of it this way ...
1m=10^2cm
or
10^{-2}m=1cm
But what about when it is meters cubed to centimeters cubed? Isn't something different there?
1m=10^2cm
cubed ...
(1m)^3=(10^2cm)^3
which becomes
1m^3=10^6cm^3
  • · Replies 21 ·
