How Do Volumes of Reactant Gases Compare to Product Gas in Ammonia Synthesis?
The discussion focuses on the stoichiometry of ammonia synthesis, specifically the reaction 3H2(g) + N2(g) -> 2NH3(g). To produce 2.00 x 10^3 L of ammonia gas (NH3), 3.00 x 10^3 L of hydrogen gas (H2) and 1.00 x 10^3 L of nitrogen gas (N2) are required. The key point is that the reaction results in a reduction of gas volume, as four volumes of reactants yield only two volumes of product, demonstrating the principles of gas behavior under constant temperature and pressure.
  • Understanding of gas laws and stoichiometry
  • Knowledge of the ideal gas law
  • Familiarity with chemical reaction equations
  • Basic concepts of molar volume at standard temperature and pressure (STP)
  • Study the ideal gas law and its applications in chemical reactions
  • Learn about molar volume and its significance in gas reactions
  • Explore the concept of gas compression and volume reduction in reactions
  • Investigate real-world applications of ammonia synthesis in industry
Chemistry students, educators, and professionals in chemical engineering or industrial chemistry who are interested in gas reactions and stoichiometric calculations.
ND3G
Suppose that you want to prepare 2.00*10^3 L of ammonia gas, NH3 , from the reaction of hydrogen gas with nitrogen gas. What volume of hydrogen and nitrogen do you need? Assume that the temperature and pressure remain constant during the reaction.
3H2(g) + N2(g) -> 2 NH3(g)
V H2 = 2.00*10^3 L NH3 * (3 vol H2 / 2 vol NH3) = 3.00*10^3 L H2
V N2 = 2.00*10^3 L NH3 * (1 vol N2 / 2 vol NH3) = 1.00*10^3 L N2
Therefore, 3.00*10^3 L of hydrogen and 1.00*10^3 L of nitrogen is required to make 2.00*10^3 L of ammonia.
This is an example in my textbook. My question is: how is it that when 3000L of hydrogen and 1000L of nitrogen are combined it produces only 2000L of ammonia?
Is the question stated incorrectly, is it taking into account only one volume of ammonia produced, or does the chemical reaction between hydrogen and nitrogen produce a more closely condensed ammonia gas?
Your textbook is not wrong. If you look at the equation, four molecules on the left produce 2 molecules of ammonia. So, it makes sense that 4000L are required to produce 2000L of ammonia.
So, does a mole of ammonia, take up the same physical space as either a mole of hydrogen or nitrogen would on their own? By combining the two is the total volume of gases reduced?
3 vol H2 + 1 Vol N2 = 2 Vol NH3
3L H2 + 1L N2 = 2L NH3
At standard temperature and pressure, one mole of any gas will occupy the same volume (~22L I think). So yes, if the reaction was to work completely, then you would be left with a yield of half the volume of the gases you put in.
13K
16K
