Volume when an equilateral triangle rotates around its base
  • Level: Undergrad
  • Thread starter youxcrushxme
    Cylinders
2 replies · 3K views · last reply
youxcrushxme
I'm having trouble on this problem -
Find the volume of the object created by rotating an equilateral triangle around its base. Solve using both shells and cylinders.
Any help would be appreciated :)
Firstly you have to determine the radius of the circunference who contains the triangle. ( see the graphic below)
- triangle is an equilateral triangle, because that the angles are 180/3= 60º
If we draw the radius we have half angle ; 60/ 2 = 30 º
Whe aply trigonometry :
Cos 30 = (side/2)/ Radius --> Here you have only one unknown (radius)
Now, yo have by rotation generated circunference Radius, and the volume of the piece will be :
V = Pi*(R)^2*H
:smile:
  • Equilateral triangle inscribed in a dark red circle, with a line drawn from one base vertex to the centre and labelled R for the radius.
mmm... where is the axis of rotation that creates the volume?
