Water pump design of an engine?
The discussion centers on the design of an engine utilizing a water pump concept, specifically focusing on the adaptation of turbine blades for air propulsion. The user explores the potential of modifying water pump blades to achieve thrust in an engine, drawing parallels to turbo-jet engines that utilize automotive turbochargers. Key challenges include maximizing energy transfer from air to the blades while minimizing efficiency losses due to unutilized energized air. The conversation highlights the innovative approach of applying fluid dynamics principles from water pumps to air-based propulsion systems.
  • Understanding of fluid dynamics principles
  • Familiarity with turbine blade design
  • Knowledge of turbo-jet engine mechanics
  • Experience with automotive turbochargers
  • Research turbine blade optimization techniques for air propulsion
  • Explore the design and functionality of turbo-jet engines
  • Investigate efficiency improvement methods in air-based propulsion systems
  • Learn about the principles of fluid dynamics as applied to both liquids and gases
Engine designers, aerospace engineers, and automotive enthusiasts interested in innovative propulsion systems and fluid dynamics applications.
aseylys
Hey all,
So I'm trying to figure out a design for an engine that will fit in a rectangle space, longer horizontally than vertically, so I thought of a water pump. A water pump is a blade that channels one stream of water into another channel.
Picture:
So then I thought why can't I do the same thing with air? If I alter the turbine blades a little could the same output effect be given?
And to extend, if this does work, how would I be able to increase the output thrust?
You would have to radically change the blades... In the pump, the blades are giving out energy to the water/liquid. In an engine, the blades would have to be receiving as much energy as possible from the air passing by it. Even then, you will have efficiency losses due to energized air passing by the blades without contributing to the blades motion...
Have you heard of a turbo-jet engine? It's a jet engine made from an automotive turbo charger. It works on the same principals you were thinking of about the water pump.
http://www.youtube.com/watch?v=uZaaLhkoHCw&feature=related
http://www.youtube.com/watch?v=LXKsrZjSwF4&feature=related
