Wave function in linearly increasing potential well from x=0 to E=V0
5 replies · 4K views · last reply
Brydan
[Note: no template because this post was moved from the QM subforum]
I was working on problem #41 and was confused about what the wave function would look like from the time x = 0 to when E=V0. (See image in attachments)https://mail.google.com/mail/u/0/?ui=2&ik=be26b6c94d&view=fimg&th=14c66f8d9fef8e09&attid=0.1&disp=inline&realattid=1497006575826501632-local0&safe=1&attbid=ANGjdJ9_sVoeG4InQCcYyJgM9GdXq5BJUBa-YH0cv1QCny82hco_1lvkH8I3AvpB_3B_zcwK5VVtj8BIZFl_yafUAFkA85LYwtvbi40WKWRnP6ch-psjeDgoFr6Vf7k&ats=1427656728466&rm=14c66f8d9fef8e09&zw&sz=w1896-h859In class we did this problem and my professor drew something on the board that looked similar to the image below, where both the amplitude and wavelength decrease from when x = 0 to when E = V0.
Hand-drawn sketch of a wave function: a damped oscillating curve whose peaks shrink and spacing narrows as it moves rightward, a horizontal line at the top, a dashed line labeled E, and a rising straight line crossing it.
However, I don't understand this solution. as according to the equations below, the wavelength should be increasing:
Handwritten derivation: p = sqrt(2m(E - V0)), then lambda = h/p = h/sqrt(2m(E - V0)), concluding that as (E - V0) decreases, lambda increases.
Additionally, I don't understand why the amplitude would be decreasing.
I was wondering if anyone could perhaps clarify what the amplitude and wavelength should be doing and why. My test is tomorrow so any help would be greatly appreciated. Thanks!
  • Graph of a linear potential V(x) rising from -V0 at the vertical axis, with a dashed horizontal line marked E crossing the slope; labelled Energy, Position, and V.
In this problem, ##E## and ##V_0## are constants so thinking about what happens as the one approaches the other is distracting you from the point of the problem.
But since V0 is increasing linearly wouldn't it not be considered a constant?
Suppose you made a crude approximation of that linearly-varying potential with (say) three sequential finite-wells...(which must be joined appropriately at their boundaries)...
The graph is wrong for two reasons, just to the left of x=0 the particle has its greatest kinetic energy and moves the fastest and is least likely to be found in some small interval. Near the point where the energy is nearly all potential the particle moves slowly and is more likely to be found. You should know which region has the shortest wavelength.
Hello Brydan, I hope you did well on the test. Your own hand-written thingy is along the lines of Spinnor's input and seems healthy to me. It's just that you used V0 instead of V there that confused Nugatory and yourself. So you should be able to qualitatively improve on teacher's rough sketch. And explain. Which is all the exercise requires.
Must say I have no idea what the composer of the exercise means with 'outside the potential well'. All I can distinguish is a region E > V and a region E < V.
