Wave interference of loudspeakers
  • Thread starter Thread starter dtesselstrom
    Interference Wave
The discussion centers on the phase difference between two loudspeakers emitting sound waves of the same frequency along the x-axis. When speaker 2 is positioned 10 cm behind speaker 1, the sound intensity is at a minimum, while it reaches a maximum with an amplitude of 2 when speaker 2 is 30 cm in front of speaker 1. The correct phase difference is calculated using the formula phase difference = 2π(deltax/wavelength) + initial phase difference. The initial phase difference is not simply π but requires adjustment based on the distance between the speakers and the wavelength of 80 cm.
  • Understanding of wave interference principles
  • Familiarity with sound wave properties, including amplitude and intensity
  • Knowledge of phase difference calculations in wave mechanics
  • Basic skills in diagramming wave interactions
  • Study the concept of constructive and destructive interference in sound waves
  • Learn how to calculate phase difference using various initial conditions
  • Explore the impact of distance on sound wave interference patterns
  • Review the principles of wave propagation and wavelength calculations
Acoustics engineers, physics students, audio technicians, and anyone interested in understanding sound wave interference and its practical applications in loudspeaker setups.
dtesselstrom
Two loudspeakers emit sound waves of the same frequency along the x-axis. The amplitude of each wave is . The sound intensity is minimum when speaker 2 is 10 cm behind speaker 1. The intensity increases as speaker 2 is moved forward and first reaches maximum, with amplitude 2 , when it is 30 cm in front of speaker 1. What is the phase difference between the two speakers.
phase difference=2*pi*deltax/wavelength+initial phase difference
I tried using this equation but I got the wrong answer. I said delta x was 30cm, wavelength is 80cm and initial phase difference is pi. Could anyone tell me where I am going wrong with this equation?
I think you have the wavelength correct. How much of a wavelength is the initial offset of 10cm? And what is happening when they are 10cm apart? So the phase difference is not pi, it's pi with an offset of...
I tried doing that but I must of misunderstood you because it still tells me I am wrong. I did 10cm/80cm * 2pi and this is still wrong.
Draw a diagram for yourself. When speaker 2 is 10cm behind speaker 1, you are acheiving what kind of interference? What does that say about the phase shift in the air between the two signals? So if speaker 2 was right next to speaker 1 and you had this kind of interference, what would the phase offset be? Now when you move speaker 2 10cm away from speaker 1, how much of a wavelength is that? So what do you have to offset the original phase difference by? Does it increase or decrease the original phase difference?
Just use the sketch and be careful about your signs. You'll get it. I got to go for a while. Good luck!
  • · Replies 19 ·
