Solve Superposition Wave: Prove, Phase Angle & Amplitude
  • Thread starter Thread starter Const@ntine
    Superposition Wave
The discussion focuses on solving the superposition of two waves: y1(x,t) = 5.00sin(2.00x - 10.0t) and y2(x,t) = 10.0cos(2.00x - 10.0t). The resulting wave can be expressed as y = A*sin(2x - 10t + φ), where the amplitude A is calculated to be approximately 11.2 m and the phase angle φ is determined to be 1.12 radians (or 63.4 degrees). The participants emphasize the use of trigonometric identities to derive these values and confirm the wave's sinusoidal nature.
  • Understanding of wave functions and superposition principles
  • Familiarity with trigonometric identities, specifically sin(a + b)
  • Basic knowledge of amplitude and phase angle in wave mechanics
  • Ability to manipulate and solve equations involving sine and cosine functions
  • Study the derivation of wave superposition in physics
  • Learn about the application of trigonometric identities in wave analysis
  • Explore the relationship between amplitude, phase angle, and wave interference
  • Investigate the implications of wave superposition in real-world applications, such as sound and light waves
Students studying wave mechanics, physics educators, and anyone interested in understanding wave superposition and its mathematical implications.
Const@ntine
a) Prove that the wave that is the result of the superposition is a function of sin.
b) What's the phase angle and amplitude of said wave?
y = y1 + y2
Initially I figured I'd work y2 into a sin function like this: y2(x,t) = 10.0sin(2.00x - 10.0t + π/2). Then take the y = y1 + y2 formula:
y = 5.00(sin(2.00x - 10.00t) + 2sin(2.00x - 10.0t + π/2))
Then I'd set 2.00x - 10.0t = a & π/2 = b, and rework the latter with: sin(a+b) = sin(a)*cos(b) + cos(a)*sin(b)
But if I put that in the above equation, I just end up with y = 5.00sin(2.00x - 10.0t) + 10.0cos(2.00x - 10.0t)
I checked around to find any formulas or theory about waves without the same amplitudes and whatnot, but my book has only the one case (same direction, same A, sin).
Any help is appreciated!
Since both the sine and cosine have the same phase function, you can make the ansatz ##y = A\sin(2x-10t+\phi)##. You can then use the trigonometric identities you mentioned to find the constants ##A## and ##\phi##.
Sorry for the extremely late reply (I marched on to thermodynamics and forgot about it), but when you say "trigonomic identities" you mean sin(a+b) = ... ? Apart from that, (a) says that I have to prove the wave is a sin function, so don't know if I could make an ansatz.
Of course you can make an ansatz if you later show that it is true and identify the constants.
I guess. It's just that it broke down the exercise into two questions, and I figured I had to do it this one way, and no other. I'm still kinda stuck on it though. Let's say I make the above ansatz, set (2x - 10t) = a & φ = b, and then follow with:
sin(a+b) = sin(a)*cos(b) + cos(a)*sin(b) = sin(2x - 10t)*cos(φ) + sin(φ)*cos(2x-10t)
What then?
Darthkostis said:
What then?
Then you figure out what values ##\phi## and ##A## have to take for the expression to be identical to your superposition.
Don't I have to connect the above equation with the info I have? I don't see how I can do that though. I have this equation as well (y = y1 + y2):
y = 5.00sin(2.00x - 10.00t) + 10.0cos(2.00x - 10.0t)
But I'm not seeing how I can connect the two.
But this is exactly what I have been saying. You put them equal to each other and start identifying the terms.
Oh yeah, darn it. It flew right past me.
Asin((2x - 10t) + φ) = 5.00sin(2.00x - 10.00t) + 10.0cos(2.00x - 10.0t)
Asin(a+b) = A*[sin(a)*cos(b) + cos(a)*sin(b) = sin(2x - 10t)*cos(φ) + sin(φ)*cos(2x-10t)]
So:
Asinφ = 10
Acosφ = 5
______________
tanφ = 2 => φ = 1.12 rad = 6.4 degrees
Asinφ = 10 <=> A = 11.2 m
Thanks a ton for the help and the patience!
1.12 radians are not 6.4 degrees...
Also, a more direct approach to solve for A without computing the phase shift is
A^2\cos^2\phi + A^2\sin^2\phi = A^2 = 100+25 = 125 \quad \Longrightarrow \quad A=\sqrt{125}\simeq 11.2
Likes Const@ntine
I meant to write 63.4 but my keyboard's a bit busted (2,3 & the spacebar don't really work).
