Wavelength - differences in equations
  • Context: Undergrad
  • Thread starter Thread starter The_ArtofScience
    Wavelength
The discussion centers on the calculation of the wavelength of electrons with an average speed of 1.7e+8 m/s. The correct formula for determining the wavelength is λ = h / p, where p represents the momentum of the particle. The formulas λ = h/mv and λ = hc/E are specific cases applicable under different conditions; the former is for non-relativistic electrons, while the latter is for massless photons. Given the speed of the electrons exceeds half the speed of light, the relativistic momentum must be considered for accurate calculations.
  • Understanding of quantum mechanics principles, particularly wave-particle duality.
  • Familiarity with the de Broglie hypothesis and its implications for material particles.
  • Knowledge of relativistic momentum and its calculation.
  • Basic grasp of photon energy and the relationship between energy, frequency, and wavelength.
  • Study the derivation and applications of the de Broglie wavelength formula.
  • Learn about relativistic momentum and its significance in high-speed particle physics.
  • Explore the Rydberg formula for calculating electron transitions in hydrogen atoms.
  • Investigate the differences between ultraviolet and visible light in terms of electron transitions.
Students and professionals in physics, particularly those focused on quantum mechanics, particle physics, and atomic transitions. This discussion is beneficial for anyone seeking to deepen their understanding of wave-particle duality and electron behavior in various energy states.
The_ArtofScience
Hi
If I wanted to find a wavelength of electrons having an average speed of 1.7e+8, would use lamdba = h/ mv or lamdba = hc/ E? I noticed that the 2nd eq is used mostly for transition states when an electron either falls or jumps from its n shell. What's the major difference?
Thanks in advance
In the beginning of 20th century the interplay of special relativity of Einstein and the photon quantization hypothesis of Planck (that light is emitted or absorbed in parcels of energy E = h nu, called photons) lead to the formula
lambda = h / p
applicable to photons. Around 1922 de Broglie guessed that material particles like electrons may also have a wave associated with them so he postulated the same exact formula applies to electrons and other material particles.
The moment of the mass zero relativistic photons is p = E/c which leads to lamdba = hc/ E.
The moment of non-relativistic electrons is p = mv, leading to lamdba = h/mv.
Your two formulas are just two particular cases of the same master formula.
I assume the speed is in m/sec.
Neither one. The correct starting point for the wavelength is \lambda = h / p where p is the momentum of the particle.
\lambda = h/mv uses the non-relativistic momentum p=mv instead of the relativistic momentum p = mv / \sqrt {1 - v^2/c^2}. Your speed is more than half the speed of light, so it makes a significant difference.
\lambda = hc/E[/itex] applies only to massless particles like photons, for which E = pc, that is, p = E/c.
Thanks guys
I'm also wondering about what electron transitions correspond to a UV light coming out from a hydrogen atom. How do I calculate that? And how do I differentiate that from the visible light?
  • · Replies 48 ·
