Waves, solving Energy with position?
8 replies · 2K views
sjmacewan
Howdy,
This is only for a second year course, but i didn't think it would get answered in the intro forums...
Ok, the wording of this question doesn't make much sense to me, but I assure you that this is what it says...
Demonstrate how
[tex]x=A \cos (\omega t+\phi)[/tex]
can be the answer for
[tex]E=\frac{1}{2}m\frac{dx}{dt}^2 + \frac{1}{2}kx^2[/tex]
I just don't see how this could possibly work. Any ideas would be helpful
As for my thoughts, I figured that either the question was written wrong, or that using the simplified energy eq'n (E=kA^2) would help...but I get nowheres using that still.
sjmacewan said:
Demonstrate how
x=Acos(wt+phi)
E=1/2m(d^2x/dt^2)^2 + 1/2k(x^2)
There's a typo in that last equation. d^2x/dt^2 is the acceleration, not the speed.
thanks for pointing that out, it was supposed to be velocity so i edited it to say such. I was mixing two questions together for a second...i still don't know what to do though
Just plug your equation for x into the energy equation and see if it makes sense as a solution.
no, that would just complicate things. when i actually subsititute the derivative in the first eq'n i can simplify it easily to [tex]E= \frac{1}{2} k A^2[/tex] but that doesn't answer the question...what it seems to want is for you to show how [tex]x=A \cos (\omega t+\phi)[/tex] actually IS the answer for [tex]E=\frac{1}{2}m\frac{dx}{dt}^2 + \frac{1}{2}kx^2[/tex]
which just sounds absurd to me.
hmmmm 40+ views and nothing. I personally think that the question must be wrong, but I'll continue to check back in case anyone sees a relationship that I'm missing between the two expressions
Solve it as a differential equation? You have [tex]\frac{dx}{dt}^2[/tex] and [tex]x^2[/tex], so if you try [tex]x=A'e^{\lambda t}[/tex] it should work. Just a suggestion, I'm not 100% on this.
I'm a bit puzzled why you ignored my advice to just plug it in and see if it satisfies the equation. That's the simplest way to verify a proposed solution to any equation! And that seems to be all you are asked to do: Just demonstrate that the given function of x is a solution to the energy equation. And it is!
I'm sorry, I guess I just misunderstood what the question was asking really...
if you just plug it in and work though it you get the [tex]e=\frac{1}{2}kA^2[/tex] equation that one would expect, I just didn't think that THAT was what the question wanted.
Either way, sorry for ignorning your advise, but what you said is the only thing that I myself though about doing, and I wasn't convinced that was right.
