Way to generalize the relationship between T and T^2?
  • Context: Graduate
  • Thread starter Thread starter mind0nmath
    Relationship
The discussion centers on the diagonalizability of linear transformations T and T^2 in finite-dimensional vector spaces. It is established that if T is diagonalizable, then T^2 is also diagonalizable; however, the reverse implication does not hold in general. A counterexample is provided with nilpotent matrices, where T^2 can be diagonalizable while T is not. The discussion also touches on the conditions under which matrices can be diagonalized, particularly in relation to eigenvalues and the spectral theorem.
  • Understanding of linear transformations and their properties
  • Familiarity with diagonalizable matrices and eigenvalues
  • Knowledge of nilpotent matrices and their characteristics
  • Basic concepts of spectral theorem in linear algebra
  • Research the properties of nilpotent matrices and their implications for diagonalizability
  • Study the spectral theorem and its applications in diagonalization of matrices
  • Explore counterexamples in linear algebra to understand the limitations of diagonalizability
  • Learn about the relationship between eigenvalues and the diagonalizability of transformations
Mathematicians, students of linear algebra, and anyone interested in the properties of linear transformations and matrix theory.
mind0nmath
Hey,
I know that if T(linear transformation in finite dim-vector space) is diagonalizable, then the matrix A that represent T is diagonalizable if there exist a matrix P=! 0 that is invertible and A=P^-1 * D * P for a diagonal matrix D.
I also know that raising A to a positive power will equal the right side with D raised to that same power. i.e. A^n = P^-1 * D^n * P
Does this imply that if T is diagonalizable so is T^2? what if T^2 is diagonalizable, then does that imply T is diagonalizable?
I think that it is an iff statement. Can anyone shine some light into this situation? maybe a counter example? is there a way to generalize the relationship between T and T^2?
T diagonalizable certainly means T^2 is diagonalizable. The reverse implication is false, in general. To see why: if t is an e-value of T, then t^2 is an e-value of T^2. Now, what if s is an e-value of T^2? We're surely going to want sqrt(s) an e-value of T, but what if the matrices are over R and s=-1?
So if T is over the complex numbers, then both directions are true?
i.e. T is diagonalizable <=> T^2 is diagonalizable?
no. the standard example of a on diagonalizable matrix is a nilpotent matrix. so if T^2 = 0, then T^2 is obviously diagonal but T may not be.
e.g. differentiation of linear functions is square nilpotent, but there are no linear functions such that Df = af except f =0.
I thought for T to be diagonalizable, it should have dimT distinct eigenvalues or dim(T) linearly independent eigenvectors. Then how is the Zero matrix diagonalizable? aren't the roots all the same(i.e. =0)? and null(T)=C^n?
It is diagonalizable by your own criteria: any basis is a set of linearly independent eigenvalues.
How about the addition of two diagonalizable matricies? Is it always diagonalizable in some basis if the field is the complex numbers?
my initial thought is: yes. by the spectral theorem. but not 100% sure since I suspect we might not be able to find a basis for the addition of the matrices which in turn would make it diagonalizable.
any thoughts??
Have you attempted to find a counterexample? Keep in mind that a nonzero nilpotent matrix is not diagonalizable.
Here's a new question(related to the subject). Is the 2x2 matrix with only a scalar in the right upper corner and all other entries = 0, diagonalizable? That matrix, call it T, is nilpotent. T^2 is the zero matrix. Isn't the zero matrix diagonalizable? it is in the diagonal form so it must be. Is T diagonalizable??
If the scalar in the upper right corner is nonzero, then no, this matrix is not diagonalizable. It's been pointed out twice in this thread that a nonzero nilpotent matrix is not diagonalizable (general nxn matrices even, not just 2x2s) -- try to prove this.
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 20 ·
20K
