Ways to prevent jet fuel contamination
  • Thread starter Thread starter djeitnstine
    Fuel Jet
10 replies · 11K views
djeitnstine
Hi guys, are any of you familiar with jet fuel contamination? I'm doing a research paper on ways to reduce or prevent it. Any input and or links would be appreciated.
Thanks in advanced
I would ask this question to Fred, he designs jet engines for a living.
Whoa that's awesome. Thats the career path I want to take. I'm guessing his user name is simply 'Fred' so i can just message him?
Jet fuel is made to strict quality control standards.
Why do you think that jet fuel is contaminated?
What is it contaminated with?
I think the OP means when it is stored in the aircraft or at the point of refuelling, not how it was manufactured.
to the OP: It's FredGarvin that's into the jet R&D and a pretty helpful guy to boot.
You're starting off with a pretty broad statement when you say contamination. I would first research the different forms of contamination that can exist...for example,
- bacterial
- microbial
- foreign object
- water
- ice (akin to water contamination but desrves it's own heading)
As far as links go, there aren't many out there for free. Some of the ones I know of are:
http://www.chevronglobalaviation.com/docs/aviation_tech_review.pdf
http://www.google.com/url?sa=t&source=web&ct=res&cd=5&url=http%3A%2F%2Fwww.burnsmcd.com%2Fportal%2Fpage%2Fportal%2FInternet%2FContent_Admin%2FPublications%2520Repository%2FTechBriefs%2520Link%2520Repository%2Farticle-jetfuelquality-001.pdf&ei=NJ-ZSfCiKKCYNZ3NnfEL&usg=AFQjCNEFtg1AW-APfSIT1G9AJz6eVuuHng&sig2=OPXyRTLdhAXtYU3iD62XBg
http://www.google.com/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.faa.gov%2Fairports_airtraffic%2Fairports%2Fresources%2Fadvisory_circulars%2Fmedia%2F150-5230-4A%2F150_5230_4a.pdf&ei=vZ-ZSa6OH4TYNPrcoIkM&usg=AFQjCNGk5AsmBIEefrUQ2R2NrgOmChA58g&sig2=rGMev_oqxNgawALaqCpuuA
Others:
http://www.astm.org/BOOKSTORE/PUBS/1005.htm
http://www.crcao.com/reports/aviafuel/CCGFS.htm
http://openlibrary.org/b/OL4487541M
http://www.google.com/url?sa=t&source=web&ct=res&cd=8&url=http%3A%2F%2Famd.nbc.gov%2Flibrary%2Fdm%2Ffuel_hb.pdf&ei=VqCZSZrTIJjAtgeG8vGwCw&usg=AFQjCNF346Cdwo6AoaAXFALVnlg7n_Sf6w&sig2=aqiVc5NTWVwfeaCGi-0d8w
http://www.aiaa.org/content.cfm?pageid=406&gTable=mtgpaper&gID=7933
Sorry I didn't state it in my opening statement but its bacterial and microbial. Preferably microbial though. Thank you fred for the links.
Basically my report is on "What is microbial contamination in jet fuels and methods to reduce it" Do you think I can create a decent analytical report on this topic? Or will I simply be regurgitating pre-analyzed reports on this topic.
Well, considering the vast amount of work done in this area, I can't really see you doing much other than reviewing existing works. Then again, I don't know how much of a chemist you are. It is my understanding that there are not that many aspects to what supports microbial growth...food, water, air... I can't really answer that for you. You need to be the judge after some of your preliminary research.
Ok thank you Fred. I think I will just settle for making a really good analytical report.
Microbial growth is not all that common, and is not just a problem with jet fuel, as it also appears in diesel fuel and other hydrocarbons.. When you do find it the appearance is similar to coffee grounds.
Regular draining of water can prevent it and the fuel also contains a biocide to prevent it.
Here are some sites with more info:
http://www.aviationnews.com.au/News_Stories/Archived_Stories/0059887-FuelFungus_CRC.htm
http://www.dieselsolutions.co.nz/the-diesel-bug.shtml
http://www.monografias.com/trabajos44/the-water-contamination/the-water-contamination2.shtml
http://www.amtonline.com/publication/article.jsp?pubId=1&id=1201&pageNum=2
