Weight on a Hypothetical Planet
The discussion revolves around calculating the weight of a person on a hypothetical planet with a mass of 1/100 that of Earth and a radius of 1/4 that of Earth, given their weight of 600 N on Earth. Participants are exploring the gravitational force equation and the implications of mass and radius ratios on weight.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the gravitational force equation and its application to the problem. There are attempts to rearrange the equation to express weight on the hypothetical planet in terms of known values. Questions arise regarding the necessity of knowing Earth's mass and radius versus using ratios. Some participants express confusion about the calculations and seek clarification on potential errors in reasoning.
There is an ongoing examination of the calculations and assumptions made by the original poster. Some participants have offered guidance on simplifying the approach and checking unit consistency. The discussion reflects a mix of interpretations and attempts to clarify the correct application of ratios without reaching a consensus on the final answer.
Participants note the importance of correctly applying ratios of mass and radius, as well as the gravitational constant. There is an acknowledgment of the original poster's confusion and the potential for mistakes in calculations, particularly in the context of an exam setting.
raptik
The mass of a hypothetical planet is 1/100 that of Earth and its radius is 1/4 that of Earth. If a person weight 600 N on Earth, what would he weigh on this planet
F = (G x M x m)/(R2)
Well I know the mass of the person is the same so I rearrange this equation in terms of m and make it equal to the two equations based on their different conditions:
m = (Fe x Re2)/(Me x G) = (Fp x Rp2)/(Mp x G)
Working out for Fp I get Fp = (Mp/Me) x (G/G) x (Re2/Rp2) x Fe = 100 x 1 x (1/16) x 600N = 3750 N.
This is wrong. Somebody please help me understand what I'm doing wrong. What's the error in my method?
You have the equation for force exerted by the planet.
You know G (a constant), M (1/100 the mass of the earth), and R (1/4 the radius of the earth).
All you need is the mass of the person. If the Earth exerts 600N on this person, then his mass is equal to 600N/(9.8N/Kg). Just plug in all your values and it should be correct. I think you are just overcomplicating the process of finding the mass of the person. And also make sure that all of your units are correct.
If you think about it, the answer you have doesn't make sense. The force should me much smaller since the mass of the planet is much smaller while the radius doesn't change that much.
So the only way to solve this is to know the actual values of Earth's mass and Radius and adjust to their respective ratios and plug in the m? I was hoping there would be a way to simply utilize the ratios without having to know the Earth's mass or Radius. Also, I understand that my answer is wrong, but could you tell me where exactly I'm going off course. In theory, I think my idea works but clearly it doesn't. Could somebody explain why?
Your method is fine. You just got the ratios Mp/Me and Re2/Rp2 backwards when you plugged in the numbers.
Like I said before, to find the mass you don't need to use the mass and radius of the earth. The gravitational force on the surface of the Earth is 9.8 N/Kg. So take 600N/(9.8N/Kg) and it will give the mass of the person.
Oh! Clearly. I can't afford to have those kinds of stupid mistakes on an exam. Thnx for pointing that out, I would have totally overlooked that.
  • · Replies 23 ·
  • · Replies 62 ·
