What approximation simplifies relativistic force to Newtonian acceleration?
8 replies · 3K views
Jontafin410
Newton's Second law of motion F=ma, where m is the mass of the object that undergoes an acceleration a due to to an applied force F. This law is accurate at low speeds. At high speeds, we use the corresponding formula from Einstein's theory of relativity
F=m[tex]\frac{d}{dt}[/tex]([tex]\frac{v(t)}{\sqrt{1-\frac{v(t)}{c}}[/tex])
Where v(t) is the velocity function and c is the speed of light. Compute
v^2
What has to be "ignored" to simplify this expression to the acceleration a=v'(t) in Newton's second law?
do you mean
[tex] F = m \frac{d}{dt}\frac{v(t)}{\sqrt{1-\frac{v(t)}{c}}}[/tex]
what do you think?
At low speeds, is the ratio of v to c significant?
lanedance said:
do you mean
[tex] F = m \frac{d}{dt}\frac{v(t)}{\sqrt{1-\left(\frac{v(t)}{c}\right)^2}}[/tex]
what do you think?
Fixed it for you.
no =) it such a small number it can be neglected. so ignore the ration. thank you
Yea the equation thing on the sight is confusing. What would the derivative of that equation be?
Well, firstly, I believe that it is [itex]F=ma\gamma[/itex], where [tex]\gamma=\frac{1}{\sqrt{1-\left(\frac{v}{c}\right)^2}}[/tex]. But I'm not certain.
[tex]F=\frac{dp}{dt}=\frac{d(\gamma mv)}{dt}=m\frac{d}{dt}(\frac{v}{\sqrt{1-\frac{v^2}{c^2}}})}\neq\gamma ma[/tex]
You can't simply pull the gamma out of the derivative because it's v-dependent. You need to take the derivative. You can use the chain rule and the division rule.
