What are the coordinates of the upper cylinder? (and some algebra)
The coordinates of the upper cylinder in the discussed problem are defined as (x_1 + 2R \sin \theta, 3R - 2(R - \cos \theta)), where x_1 = -R \theta_1 represents the x-coordinate of the lower cylinder. The y-coordinate of the upper cylinder is derived from geometric considerations, yielding y_2 = 3R - 2R(1 - \cos \theta). The algebraic challenge involves combining two equations to eliminate \theta_1 and derive the equation \dot \theta^2 (18 - (1 - 2 \cos \theta)^2) = \frac{1}{2} R (1 - \cos \theta) g.
  • Understanding of basic geometry involving cylinders
  • Familiarity with trigonometric functions and their applications
  • Knowledge of calculus, particularly derivatives
  • Ability to manipulate algebraic equations
  • Study the geometric properties of rolling cylinders and their coordinate systems
  • Learn about the small angle approximation in trigonometry
  • Explore methods for solving systems of equations in physics
  • Investigate the principles of rotational dynamics and kinematics
Students and educators in physics and mathematics, particularly those focusing on mechanics, geometry, and algebraic problem-solving related to rotational motion.
JD_PM
1) Get the coordinates of both the lower and upper cylinders.
2) Combine the two given equations to get the given result.
1) ##( x_1 + 2R \sin \theta, 3R - 2(R-\cos \theta))##
2) Combine
$$\frac 1 2 M R^2 \Big( 3 \dot \theta_1^2 + 2 \dot \theta_1 \dot \theta(1 - 2 \cos \theta) + 6 \dot \theta^2 \Big) + 2MR(1 + \cos \theta)g = 4MRg \ \ \ \ (1)$$
$$MR^2 \Big(3 \dot \theta_1 + \dot \theta ( 1 - 2 \cos \theta) \Big)=0 \ \ \ \ (2)$$
To get
$$\dot \theta^2 \Big( 18 - (1 - 2 \cos \theta)^2 \Big) = \frac 12 R (1 -\cos \theta) g$$
I was solving a problem and got stuck in two aspects:
1) Geometric issue.
Alright, I understand that the coordinates of the lower cylinder are
$$( -R \theta_1, R)$$
The coordinates of the upper cylinder are:
$$( x_1 + 2R \sin \theta, 3R - 2(R-\cos \theta))$$
I get that the ##x## coordinate of the upper cylinder is ##x_2 = x_1 + 2R \sin \theta##
But I do not understand why ##y_2 = 3R - 2(R-\cos \theta)##.
2) Algebraic issue
I have the following two equations:
There has to be a way to combine them such that we eliminate ##\theta_1## to get:
But I do not see it. What I have done is multiply the second equation by ##-\frac{\dot \theta_1}{2}## and then add both up. Like that I just get rid of the first terms of both equations.
Could you please give me some hints on 1) and 2) issues?
Thanks.
JD_PM said:
Homework Statement:: 1) Get the coordinates of both the lower and upper cylinders.
Relevant Equations:: 1) ##( x_1 + 2R \sin \theta, 3R - 2(R-\cos \theta))##
2) Combine
To get
1) Geometric issue.
2) Algebraic issue
Thanks.
You really need to give more details and give the context for this problem.
It looks like it might be posted in the wrong forum. You have derivatives (Calculus) here, and perhaps kinematics relevant to a physics course.
As far as I can tell:
  1. You have two cylinders (each of radius, R) in contact.
  2. When you refer to the coordinates of a cylinder, you mean the coordinates of the center (axis).
  3. θ is the angle that the line joining the centers makes with the vertical (measured clockwise?). At time, t=0, θ=0.
  4. θ1 is amount of rotation (counter-clockwise) made by the lower cylinder.
  5. θ2 is amount of rotation (clockwise) made by the upper cylinder.
Does the lower cylinder slip with respect to the horizontal surface and/or the upper cylinder?
What are A' and A'' ?
Alright, the whole problem is:
Is Calculus Forum the best option? I will report the question.
Both cylinders roll without slipping.
##A## is the point of contact between the cylinders at ##t=0##. This point of contact moves to ##A'## on the lower cylinder and to ##A''## on the upper cylinder at ##t>0##.
Your Geometrical issue has typing mistake. Instead of ##3R-2(R-cos\theta)##, it should be ##3R-2R(1-cos\theta)## as can be seen from geometry as well as dimensions.
For Algebraic issue:
Try using Eq 2 to substitute ##\theta_1## in Eq (1)
This (Advanced Physics Homework Help) is where I would have suggested to post this thread. (Thank you Mentor.)
Let me tackle the algebraic issue first.
Alright you propose using substitution method.
By doing so I get
$$\dot \theta^2 \Big( 6 + (1 - 2 \cos \theta)^2 \Big) = \frac 4 R g(1- \cos\theta)$$
As we already know what we are looking for, I thought of multiplying both sides by ##3## to get:
$$\dot \theta^2 \Big( 18 + 3 (1 - 2 \cos \theta)^2 \Big) = \frac{12}{R} g(1- \cos\theta)$$
But the above equation is not the same that
$$\dot \theta^2 \Big( 18 - (1 - 2 \cos \theta)^2 \Big) = \frac{12}{R} (1 -\cos \theta) g$$
Because
$$3 (1 - 2 \cos \theta)^2 \neq - (1 - 2 \cos \theta)^2$$
Mmm what am I missing?
Try again. I got the result.
Let me show what method I am using to determine the coordinates of the lower and upper cylinder.
The ##(x,y)## coordinates are taken as follows (##x## horizontal and ##y## vertical):
Coordinates for the lower cylinder
x coordinate
By straightforward geometry we get:
$$\sin \theta_1 = -\frac{x_1}{R}$$
Applying the small angle approximation ##\sin \theta_1 \simeq \theta_1## and solving for ##x_1## we get the desired result:
$$x_1 = -R \theta_1$$
y coordinate
The blue line is the radius ##R##. We get the desired result:
$$y_1 = R$$Coordinates for the upper cylinder
x coordinate
OK. The method is to obtain an equation for the orange, blue and green pieces and then add them up to obtain an equation for the thin red line.
- Orange slab
We already know an equation for it; ##x_1 = -R \theta_1##
- Blue and green slabs.
Both have the same mathematical expression: ##\sin \theta = \frac{x'}{R} \rightarrow x' = R \sin \theta##
Thus the mathematical expression for both is ##2 R \sin \theta##
Adding the mathematical expressions of the orange, blue and green slabs lead to the desired result (as expected):
$$x_2 = x_1 + 2 R \sin \theta$$
(Note: in the provided solution the small angle approximation is not applied to ##\theta## but it is applied to ##\theta_1##; why?).y coordinate (the one I am stuck in)
I wanted to use the latter method to get the desired result
$$y_2 = 3R-2R(1-cos\theta)$$
But it seems that it is not a good idea. For this method to work we would need the blue line not to cross the green slab. How can I proceed then? Should I switch method?
Any help is appreciated.
Thanks.
I will try again
Abhishek11235 thank you! The algebraic issue has been solved.
Only the geometric one is still unsolved.
x coordinateView attachment 256958
y coordinate
$$y_1 = R$$
Thanks.
There is no need to use the small angle approximation.
If the lower cylinder rotates through angle θ1, then any point on the circumference moves a distance ##R \cdot \theta_1## along the circumference of the cylinder. The cylinder moves without slipping on the horizontal surface. Therefore, the cylinder moves a distance, ##R \cdot \theta_1## in the negative ##x## direction.
As said, the given formula is wrong. The picture will be really helpful to you. Alternatively (which is how I actually got y-coordinate) , we have R distance from ground to centre of 1st sphere. Then there is 2Rcos##\theta## so that total distance is R+2Rcos##\theta##
Your picture was really helpful, thanks.
  • · Replies 21 ·
