rulo1992
- 15
- 0
Suppose a non-uniform circular motion where a particle of mass "m" is attached to a string, which rotates on a vertical plane. Once an initial velocity is provided to the particle at the lowest point of the trajectory, no further forces act on the particle. (Air drag is negligible)- Which is the minimum velocity that the particle requires to reach the highest point of the trajectory?
- If initial velocity is two-times the one we calculated in question 1, what would be the velocity in the highest point? Calculate the acceleration too:
- Calculate the maximum height the particle can reach if the velocity is half the one calculated in 1.
- Calculate the initial velocity if the particle rotates only 2\Pi/3 radians:
1/2mv^2bottom=1/2mv^2top+mg2r
Centripetal acceleration=(v^2)/(r)
v=ωr
For no.1 , given that KE is fully transformed into potential energy at the highest point of the circle,KE is 0 in the right side of the equation so: v=2√(gr)
For number 2, if velocity is 4√(gr) then 1/2m(4√(gr))^2=1/2mvtop^2+mg2r →vtop=2√(3gr)
So I tried to calculate the centripetal acceleration and I got an=(2√(3gr)/r
But know I don't know how to calculate the tangential acceleration with only the values I know and now I'm stuck on this problem. Pleasse help me!
