What are the particle's position and velocity
  • Thread starter Thread starter brad sue
    Position Velocity
The discussion focuses on calculating the position and velocity of a particle with an initial velocity of v=(30 m/s)j and a non-uniform acceleration defined by a=[3.5 m/s² +(0.7 m/s⁵)t³]i+[2 m/s²-(0.3 m/s⁴)t²]j after 30 seconds. Participants clarify that due to the powers of t in the acceleration equation, standard equations of motion cannot be applied. Instead, integration of the acceleration function is necessary to derive both velocity and position functions over time. The constants in the acceleration formula must be understood in terms of their units to ensure accurate calculations.
  • Understanding of calculus, specifically integration.
  • Familiarity with vector notation in physics.
  • Knowledge of kinematics and non-uniform acceleration.
  • Ability to manipulate and interpret units in physics equations.
  • Practice integrating functions to derive velocity from acceleration.
  • Explore kinematic equations for non-uniformly accelerated motion.
  • Learn about vector calculus and its applications in physics.
  • Investigate unit conversion techniques for physical constants in equations.
Students and professionals in physics, particularly those studying kinematics and dynamics, as well as educators looking for examples of non-uniform acceleration problems.
brad sue
I have no idea how to find a solution forthis exercice:
A particle moving with an initial velocity v=(30m/s)j undergoes an acceleration of
a=[3.5m/s2 +(0.7m/s5)t3]i+[2m/s2-(0.3m/s4)t2]j.
what are the particle's position and velocity after 30s assuming that it starts at the origin?
i am confused by the powers 4 and 5 in a . please give me some hints to answer the problem.
Brad
These powers of t shows that the motion is not uniformally accelerated and so you can't use equations of motion.
integrate the acceleration to get velocity and then for position.
a_x gets quicker and quicker as time goes by ...
by t=2s, a_x = (3.5 + 5.6)m/s^2 , a_y = (2-1.2)m/s^2 .
v(t) = v_o + integral of a(t)dt ... x(t) = integral of v(t)dt
they're just powers, but I'd do j and i separately.
The extra "powers" are the correct units of the constants that are given. the constants are part of a formula that gives an acceleration, the constant is multiplied a time (in seconds) squared or cubed, so to generate the acceleration in m/s/s the constants must be defined in m/s/s/s/s and m/s/s/s/s/s. If someone wished to do this sort of thing in a different unit of time then they would have to convert the constants into the new system of units.
but as has already been stated you really don't need to worry about them.
Writing the units in the equation makes it look more confusing than it is. You can rewrite it like this using standard units (distance in m; time in s; acceleration in m/s^2):
a=[3.5 + 0.7t3]i+[2 - 0.3t2]j
  • · Replies 16 ·
18K
