What Are the Two Cases in Calculating Steady States?
mt91
Two coupled differential equations: dn/dT = n/(1+n) - βnc and dc/dT = α - μc, followed by the instruction to calculate the steady states for the cases αβ/μ < 1 and αβ/μ > 1.
I've got this question here, I know to calculate steady states you set dn/dT and dc/dT to 0 and then solve. However can anyone help me understand what it means by the "two cases" and how you go about this?
Yes, the "steady" in "steady state" means that it does not change. "Steady State" solutions for n and c are constant solutions so the derivatives are 0. The equations become:
$\frac{n}{n+1}- \beta nc=0$ and
$\alpha- \mu c= 0$.
Since the second equation involves only c, no n, I would solve it first:
$c= \frac{\alpha}{\mu}$.
Now put that into the first equation:
$\frac{n}{n+1}- \frac{\alpha \beta}{\mu}n= 0$
$\frac{n}{n+1}= \frac{\alpha \beta}{\mu}n$
$n= \frac{\alpha\beta}{\mu}n(n+ 1)$
Obviously n= 0 is a solution to that so one steady state solution is $c= \frac{\alpha}{\mu}$, $n= 0$.
If n is not 0 we can divide by it to get $1= \frac{\alpha\beta}{\mu}(n+ 1)$.
Then $n+ 1= \frac{\mu}{\alpha\beta}$,
$n= \frac{\mu}{\alpha\beta}- 1= \frac{\mu- \alpha\beta}{\alpha\beta}$.
So if n is not 0 then $c= \frac{\alpha}{\mu}$, $n= \frac{\mu}{\alpha\beta}- 1$ is a steady state solution.
But notice the "$\frac{\mu}{\alpha\beta}- 1$". If $\frac{\mu}{\alpha\beta}= 1$ then we are back to the "n= 0" solution, above. If $\frac{\mu}{\alpha\beta}> 1$ the steady state solution for n is positive, if $\frac{\mu}{\alpha\beta}< 1$ the steady state solution for n is negative.
Was this the entire question or was there some application in which n being positive or negative would be important?
