What assumptions underly the Lorentz transformation?
120 replies · 13K views · last reply
robphy said:
"##c\rightarrow\infty##" is for physical intuition (for a layperson or a physics student).For ##E=0## (galilean) or ##E=+1## (minkowskian) , one could think of ##E## as if it were $$\left(\frac{c_{light}}{c_{max}}\right)^2,$$
as implemented in code, for example, https://www.desmos.com/calculator/kv8szi3ic8 .
(As I said in #58 , this "accounting" approach disentangles
  • "c" as a space-time unit conversion constant [which is an issue of history].
  • "c" as maximum-signal-speed [which is an issue of physics]
So, by primarily using this parameter ##E## or its equivalent [as used above],
we can avoid (or at least minimize) issues of taking limits to infinity
and move on to the other likely-more-interesting mathematical structures of the physics problem.
I don't share the view that ##c\to\infty## is for the laypeople only. After all, in mathematics as well as in physics there are a couple of situations where some quantity ##C## goes to infinity, which normally is the case when some other quantity ##D## is suppressed by the inverse of that factor and by taking that limit is essentially eliminated (as usually is ##C## at the same time, which is what happens when going from the Lorentz transformation formula to the Galilei transformation formula).
You give an example yourself: the inverse temperature ##\beta## goes to ##\infty## when ##T\to 0##. Depending on what you want to derive, it may make it much more transparent to see the impossibility to reach that value.
Regarding your differentiation between ##c_{light}## and ##c_{max}##: if ##c_{light}\neq c_{max}## then ##c_{light}## is no natural constant, it is actually not constant at all any more, because the natural constant is ##c_{max}##. The velocity of light would be dependent on the reference frame as e.g. is the windspeed on Earth. Subsequently, in your nomenclature, the 2 cases ##E=0## and ##E=+1##, which you define as ##E=\left(\frac{c_{light}}{c_{max}}\right)^2##, would be:
- a photon at rest (##c_{light}=0##)
- a photon at the speed ##c_{max}##, which however is impossible as there is no LT that maps some ##v<c_{max}## to ##v=c_{max}##. Of course, you may correct your value range by saying ##E\in[0,1)## so you have a half-open interval, which would at least be mathematically consistent.
Either way, your interpretation of ##E=0## representing Galilei, as you write, and ##E=1## representing Lorentz, is not correct.
Amemdment: actually, if ##c_{max}## has a finite value, you have Lorentz. The value of ##c_{light}## is completely irrelevant. It might be ##c_{max}##, which is the world we live in, it may be not, still we would live in a Lorentz spacetime, but with some very exotic properties of light.
vanhees71 said:
I'm not sure, what you mean by "absolute velocity", but you can indeed ask, what are the symmetry transformations for a spacetime model, in which the special principle of relativity holds in addition to the other usual symmetries, i.e., homogeneity of time and space as well as Euclidicity of space for any inertial observer. With these assumptions you indeed get only two possible spacetime models: Galilei-Newton spacetime without any additional fundamental parameter or Einstein-Minkowski spacetime, which introduces a "limiting speed" as a fundamtental parameter, which empirically is given by the speed of light in vacuo. A nice paper deriving this is
V. Berzi and V. Gorini, Reciprocity Principle and the Lorentz Transformations, Jour. Math. Phys. 10, 1518 (1969),
https://doi.org/10.1063/1.1665000
I've just seen this posting. I've never heard of this paper but will study it and see how it differs from Levy-Leblond. Thanks for mentioning this!
You are misunderstanding the approach.
##c_{light}## is a constant (like the speed of sound is).. akin to a convenient conversion unit between meters and feet. It does not vary.
##c_{max}## is the parameter that varies between theories.
Plug in the specific values of E, regardless of the relation of E to other quantities.
Do you get Euclidean, Galilean, and Minkowski accordingly?
The approach I use is based on Yaglom, Levy-Leblond (the “Additivity, rapidity, relativity” paper and the “Galilean Electromagnetism” paper), Ehlers frame theory, etc.
An old poster that needs to be written up into a paper https://www.aapt.org/doorway/Posters/SalgadoPoster/Salgado-GRposter.pdf
goes beyond just formulating the idea (not just talking about the idea)… it is implemented to discuss physical situations to show how it can be explicitly used to unify the approach to encompass Galilean and Minkowskian relativity.
See the references at the end.
( As mentioned earlier, here is
a visualization to support my approach https://www.desmos.com/calculator/kv8szi3ic8 .)
pervect said:
Thirdly, to handle two observers in relative motion who are not at the same location, we add another assumption, which states that light emitted from an inertial observer and received by another inertial observer at rest with respect to the first at a different location will experience no doppler shift, that the k factor will be unity.
Hmm so one issue I see with this assumption is that while it works purely within the idealized special relativity is this no longer applies within the extension of special relativity to general relativity as spacetime curvature induces gravitational or cosmological doppler effects.
vanhees71 said:
That's a subtle issue. On the one hand you are right: The particular value of ##c## is just a convention defining the unit of lengths in terms of the unit of time in any given system of units. In the SI they make unit of time (the second, s) the most fundamental unit, because time measurements are among the most precise measurements possible. It's still the hyperfine transition of Cs-133 used to define the second, but that may change in not too far future since there are more accurate realizations possible (either an atomic clock in the visible-light range or the nuclear Th clock). Then the unit of length (the meter, m) is defined by setting the limit speed of relativity to a certain value. Since with very high accuracy the photon is massless the realization of ##c## in measurements is simply the speed of electromagnetic waves in a vacuum.
On the other hand all this of course hinges in the existence of the limiting speed and the validity of the relativistic spacetime model. If the world were Galilean, there'd be no fundamental natural constant with the dimensions of a velocity and time and lengths units would have to be defined independently of each other with some "normals" (as it was before 1983, when the second was defined as today and the meter independently by some wavelength of a certain Kr-86 line).
Hmm interesting historical note on the meter and yeah how units are defined is nontrivial even if the choice is somewhat arbitary as not all methods have the same accuracy.
otennert said:
My 10cent: one of the most convincing "derivations" of the Lorentz transformation is by Jean-Marc L´evy-Leblond 1976: https://www.researchgate.net/publication/252687984_One_more_derivation_of_the_Lorentz_transformation
based on the 4 assumptions:
1.) Homogeneity of spacetime and linearity of transformation
2.) Isotropy of space
3.) Group law (Lorentz transformation form a group)
4.) Causality
Identification of the velocity of light with the resulting maximum velocity is then the next, but logically independent step.
The reason why I find this derivation most convincing is that some maximum velocity (as a given parameter) is the result of very general assumptions which sound much more common-sense than putting constancy of the velocity of light as a prerequisite, which -- without prior knowledge -- is much more counter-intuitive.
So one relevant caveat related to these assumptions here which sticks out is that Homogeneity and isotropy of spacetime are assumed to be valid which while it is natural in special relativity may actually be much more problematic in the context of general relativity for some subtle meta-mathematical reasons which may become relevant in terms of solving some current unsolved problems in physics and thus consequently requiring more complicated work on velocity vector addition at cosmological scales.
The problems relate to the defining properties of all systems of partial differential equations specifically how for every system of partial differential equations there exists an unique solution for all valid initial conditions, which in turn means that information on the initial conditions must be conserved at cosmological scales.
Starting from the proof of the "No big crunch theorem" proved by Matthew Kleban & Leonardo Senatore
in Inhomogenous and anisotropic cosmology(https://iopscience.iop.org/article/10.1088/1475-7516/2016/10/022/meta), you can show that at least in the limiting case of any arbitrarily nontrivial flat or open universe with 3 dimensions of space and one of time which is initially expanding that their proof falsifies the assumption that at some sufficiently large scale spacetime can be treated as relatively uniform and isotropic. In the context of systems of differential equations it isn't hard to mathematically prove such an assumption explicitly requires that information conservation be violated i.e. information must be destroyed for the assumption to hold. Given that the conservation of information is a foundational postulate of quantum mechanics this indicates homogeneity and isotropy are not a valid postulate. Oh and you also automatically get the laws of thermodynamics and the arrow of time as universal constraints on the variation of the metric within such a universe. (Though the 2nd law of thermodynamics and arrow of time in such a case appear to directionally depend on whether the universe is initially overall expanding of contracting)
In particular since the recent experimental test for the pure kinematic dipole assumption by Nathan J. Secrest et al(https://iopscience.iop.org/article/10.3847/2041-8213/abdd40) which is needed to prevent the CMB dipole from falsifying the cosmological principal being valid anywhere within the observable universe, there is now strong experimental evidence that we can't treat space as either isotropic or homogeneous at any scale within the observable universe, i.e. a significant component of the CMB dipole must arises from some cosmological effects related to the overall large scale structure of the Universe. An implication of this is that there is that the general relativistic extension of special relativistic velocity transforms will need mathematical modification based on large scale anisotropies.
##c_{light}## is a constant (like the speed of sound is).. akin to a conversion unit between meters and feet. It does not vary.
goes beyond just formulating the idea… it is implemented to discuss physical situations.
OK, so ##c_{light}## is just another numerical constant, but ##c_{max}## is a natural constant, not necessarily the speed of light, correct? It is somewhat misleading then to call it ##c_{light}## which suggests it is the speed of light -- which actually only makes sense if there is the speed of light, i.e. constant. Otherwise I can't see the physical significance. There is neither the speed of sound, although in this case of course an observer's rest frame is implied with regards to the medium (=air) -- which however is impossible to define for light unless there is a medium at rest.
But anyway, so you are saying that ##E=0## is equivalent to ##\alpha=0## in Levy-Leblond, and ##E=1=1/c_{max}## is equivalent to ##\alpha>0## in some suitable units, nothing else, correct? Understood.
I will have a look at your poster.
At the level of the “E”, yes.
The idea is not new and has been around for awhile, often rediscovered without being aware of earlier approaches.
I have been using “E” here at PF ever since I implemented the idea in Desmos to demonstrate the unified geometrical relationships explicitly in a familiar context, beyond merely classification or abstract formula.
The ##\epsilon^2## approach (inspired by Yaglom) is a gateway to developing a computational technique akin to using complex numbers as vectors in Euclidean geometry.
(That opens up another can of worms that I decided to bottle up for now… but it’s in the poster.
I claim it is all consistent but I need to learn more projective geometry to make it more understandable and palatable to a more general audience, as well as fortify proofs and calculations.)
While foundational “interpretations” may be argued about, my interpretation leads to a concrete realization that yields the appropriate formulas and geometric constructions to describe (when appropriately reduced) standard physics in standard physics notation.
In short, “E” appears in unified formulas for physics. Choosing “E=0” gets you the PHY 101 formulas, “E=1” gets you special relativistic formulas, “E=-1” gets you the Euclidean analogue…. Ideally developed with a common unified approach (common geometric construction). You don’t have unlearn everything… but loosen up rigid viewpoints to allow the transition between signatures.
Ok, so here's the thing:
If there is an invariant speed ##V##, then spacetime is Minkowski regardless of what that invariant speed is. We all agree on this as far as I can tell. The question is what happens afterwards in the line of thought. On the one hand, yes, taking the limit ##V\to \infty## formally reduces the Lorentz transformations to the Galilei transformations as long as everything else is kept constant. However, the objection here is that calling this limit ##V \to \infty## is somewhat misleading from the Minkowski geometry point of view. The reason for this is that the natural thing to do would be to use the same units for time and space directions such that the metric diagonal becomes ##\pm (1,-1,-1,-1)## depending on convention. This is in complete analogy with using the same units for the x- and y-axes in Euclidean space. In this regard, the invariant speed ##V## is simply a scaling choice between time and space units and such a scaling choice can never affect the geometry. Therefore, letting ##V\to \infty## while keeping ##v## fixed geometrically corresponds to only allowing small rapidities, which would be more accurately referred to as ##v/V \to 0##.
Compare to the Euclidean case in two dimensions. Geometrically it would be natural to use the same units for both directions, but for some applications it may be of more relevance to use nautical miles in one direction and fathoms in another. The conversion factor between those units is roughly ##K = 1012## fathoms/NM. A rotation now takes the form
x' = \Gamma ( x - ky/K^2), \qquad y' = \Gamma (y - kx),
where ##\Gamma = 1/\sqrt{1+(k/K)^2}## and ##k## is a rotation parameter (##k = K \tan\theta## where ##\theta## is the rotation angle). Formally, for ##K\to \infty## with everything else fixed, we would find
x' = x, \qquad y' = y - kx.
Geometrically, nothing changed, but our rotations of fixed ##k## became smaller and smaller rotations as ##K## increased and the formal limit no longer displays the same group structure as that of the full geometry. I think this is why many, including myself quite often, do not really like talking about the limit as ##c \to \infty##, with ##c## being just an arbitrary unit conversion factor unrelated to the actual geometry.
otennert said:
You give an example yourself: the inverse temperature β goes to ∞ when T→0. Depending on what you want to derive, it may make it much more transparent to see the impossibility to reach that value.
This is a bit of a misdirected analogy as it involves a physical quantity going into a limit. The more relevant analogy would be letting ##k_B##, which is effectively a conversion factor between units of temperature and units of energy, go to zero. Neither is really relevant of course, as the big question is typically how ##k_B T## relates to a typical difference in energies.
vanhees71 said:
Of course the deformation from the Poincare to the Galilei group has to be taken at fixed group parameter, ##v##, not at fixed ##\beta=v/c##.
... which is the same as in the Euclidean case saying that what you want to fix is for some reason the parameter ##k## above rather than the geometrically somewhat cleaner rotation angle ##\theta##.
To me, the OP looks to be asked and answered, yet this thread keeps going in circles. Does that make it an example of Thomas Precession?
No, it's a closed timelike curve. ;)
There are no closed timelike curves in Minkowski space! 😛
  • Haha
Does flat spacetime with periodic boundary conditions count as somewhat Minkowski? If not, I give up.
No, that’s a different geometry. As evidenced by the existence of closed timelike curves. 😛
PeroK said:
It's a question of what we choose first. If I choose any ##v##, then you let ##c \to \infty##, then ##\gamma(v) \to 1##. Fair enough.
But, if you choose ##c##, then I can choose any ##v < c## and we have the full range of gamma factors and the same geometry. Still Minkowski and no nearer to Galilean. So, there is no convergence from Minkowski to Gallilean
The question is which of these is correct?
I'm still puzzled. The Lorentz boost with fixed ##\vec{v}## goes to a Galilei boost when taking ##c \rightarrow \infty##. So on this very elementary level, there's not such a complicated issue in "deforming" the Poincare group to the Galilei group.
It gets more subtle in the context of quantum theory, where you deal with ray representations, and doing the "deformation" in the correct way there you end up not with the Galilei group but with a central extension of it (despite the fact that anyway you end up with the covering group too, enabling half-integer representations of the rotation group in both Poincare and Galilei groups). Proper unitary representations of the Galilei group don't lead to useful dynamics of the quantum theory (Enönü and Wigner).
Of course you can NOT use "natural units" when you want to take the Newtonian limit, because if there is no "limiting speed", ##V##, there simply is no "natural unit" for velocities/speeds and also no natural way to measure time intervals and distances in the same unit. So before you take the limit ##V \rightarrow \infty## you have to fix space and time units.
In Newtonian mechanics there is no such connection between space and time. The geometry is completely different: In Newtonian mechanics you have time and at each point in time a Euclidean space. If I remember the formalism right that's a kind of fiber bundle, while in special relativity you have a pseudo-Euclidean affine 4D manifold. I don't know, how to formally describe the limit ##V \rightarrow \infty## to deform the Minkowski spacetime to the Newtonian spacetime. I'm sure, there should be some literature about this somewhere.
I don't think that this is a good analogy, because here you stay within a fixed Euclidean geometry of the plane. There it indeed doesn't make sense to arbitrarily choose different units along different directions and then take a limit of the conversion factor.
That's of course true. So it's a difference to have a concrete physical situation, of which you make some approximation in certain limits.
In our context an example is the above quoted work by LeBellac and Levy-Leblond on the different "Galilean limits" of Maxwell's equations. After reading this paper I guess even the most anti-relativity sceptic should get convinced that relativity is the right foundation of electromagnetic theory ;-)).
Here's an example. Let$$S_n = \{\frac 1 n, \frac 2 n, \dots \frac {n-1} n\}$$For any ##k## we have:$$\lim_{n \to \infty} \frac k n = 0$$But, it would be wrong to conclude that$$\lim_{n \to \infty} S_n = \{0\}$$The pointwise argument fails to capture the limiting behaviour of the set.
Of course, you will not get exactly the GT, except for the special case of ##v=0##, by calculating in case of ##V=1##:
##\lim_{v\to0}\frac{x-vt}{(1-v^2)^{1/2}}=x##
If you are talking about "allowing small rapidities" for an approximately GT, then you must also demand "small enough x-coordinate", to limit the term for "relativity of simultaneity" (##vx/V^2##) in the transformation of time.
But nowhere does one make such a false conclusion when taking non-relativistic limits by doing an expansion in powers of ##1/c##. I don't know, where you get this idea from.
OK, but your concrete series does not correctly reflect the LT. To remain with your analogy, you should rather consider:
$$L_n = \{\frac{0}{\sqrt{1-\frac{0^2}{n^2}}}, \frac{1}{\sqrt{1-\frac{1^2}{n^2}}},\frac{2}{\sqrt{1-\frac{2^2}{n^2}}},\ldots,\frac{n-1}{\sqrt{1-\frac{(n-1)^2}{n^2}}}\},$$
then
$$\lim_{n\to\infty} L_n = \{0,1,2,3,...\},$$
which in my view correctly represents the GT in this analogy.
  • Skeptical
It is not important, if you choose a unit system with ##V:=1## or with ##V :=3\cdot 10^8 \frac{m}{s}##. You generally cannot use a constant as input to a limit calculation.
Sagittarius A-Star said:
As example, take the SI unit system, according to which ##c=3 \cdot 10^8 m/s##. It makes no sense to write:
##\require{color}\lim_{3 \cdot 10^8 \frac{m}{s} \rightarrow \infty} {\frac{1}{\sqrt{1-v^2/c^2}} (t-\color{red}\frac{vx}{c^2}\color{black})}##
I'm really confused now about these arguments. Of course you can make an expansion in powers of ##c##, and it doesn't make sense to make an expansion in powers of ##1##.
E.g., take the equation of motion of a particle in an electromagnetic field. The most simple way to get the non-relativistic limit is to formulate it in terms of the coordinate time
$$m \frac{\mathrm{d}}{\mathrm{d} t} (\gamma \dot{\vec{x}})=q (\vec{E} + \vec{v}/c \times \vec{B}).$$
Then you expand in powers of ##1/c##:
$$m \ddot{\vec{x}} +\mathcal{O}(1/c^2) = q(\vec{E} +\vec{v}/c \times \vec{B})=q \vec{E} +\mathcal{O}(1/c).$$
Depending on, whether you take everything into account up to powers of ##1/c## or only ##(1/c)^0## you get the Newtonian equation of motion either including the magnetic force or not.
That's only valid for ##v <<c##. So, you must bound ##v## by some finite ##c_0## as you let ##c \to \infty##.
The problem is that you do only an invalid pointwise convergence, then claim a universal convergence for a set of all ##v < c##.
The example I gave uses the same idea and leads to an immediate and obvious contradiction.
That's of course true. So in this case it would indeed be better to do an expansion in powers of ##\beta=|\vec{v}|/c##. That also tells you, where the approximation becomes invalid, namely when ##\beta \gtrsim 1##.
It is not only a good analogy, it is an exact analogy. Just as I am stating within a fixed Euclidean geometry, Minkowski space describes the same geometry regardless of the value of c and the geometrically natural thing to do is to use the same units for all directions. This is the point.
Sure, that is also true regardless of how you take the limit. See the discussion using ##\pi_1## and ##\pi_2## below.
1/c is generally a bad expansion parameter because it is dimensional. When controlling limits of the behavior of physical relationships, the natural tjing to do is to look at dimensionless
vanhees71 said:
Of course you can make an expansion in powers of c, and it doesn't make sense to make an expansion in powers of 1.
See above. The physical limits are those of dimensionless quantities. For dimensional quantities you can always readapt your units so that the numerical values become order one. In other words, you need a reference of some sort to be able to meaningfully say that something approaches zero or infinity.
In the case of the Lorentz transformations, the meaningful dimensionless parameters can be taken to be ##\pi_1 = v/c##, ##\pi_2 = x/ct##, and ##\pi_3 = t’/t## (for the time transformation). The limit colloquially referred to as ”##c\to\infty##” corresponds to both of those parameters approaching zero at the same rate.
The Lorentz transformations generally take the form
\pi_3 = f(\pi_1,\pi_2)
based on the Buckingham pi-theorem. In particular, we would have
\pi_3 = \gamma(\pi_1) (1 - \pi_1\pi_2).
Similarly, for ##\pi_4 = x’/x##,
\pi_4 = \gamma(\pi_1) (1 - \pi_1/\pi_2).
With ##\pi_1## and ##\pi_2## going to zero at the same rate, it is clear that the limit becomes ##\pi_3 \to 1## and ##\pi_4 \to 1 - \pi_1/\pi_2##.
(To make the transition to the GT more apparent, we could instead pick ##\pi_2 = x/vt##.)
vanhees71 said:
The Galilean limit often can be derived as the limit ##\beta=v/c \rightarrow 0##, but also a bit depends on the theory you are looking at. E.g., for mechanics the limit ##\beta \rightarrow 0## is indeed usually getting you to the non-relativistic approximation.
For the Maxwell equations it's another business, and you have to distinguish between different "Galilean limits" ("electric" and "magnetic" ones):
M. LeBellac, J. M. Levy-Leblond, Galilean electromagnetism, Nuovo Cim. 14B, 217 (1973)
Generally, I also do not understand what @PeroK is after.
I have read the paper
in a first round now, but am struggling with some basic prerequisites, or maybe motivations for their undertaking (by the way, I am happy to spin this off to a separate thread, if generally preferred):
For example, the authors make a distinction between "mostly-timelike" and "mostly-spacelike" 4-vectors. This is the first statement I am struggling with: "mostly-timelike" suggests essentially the space components are extremely small, and vice-versa for "mostly-spacelike". But a relativistic 4-vector to start with is either timelike or spacelike, invariantly so, although of course by LT, the value of the space and time components each change. In a Galilean limit, so that we are looking at a Galilei spacetime, there is no causal structure, hence no "timelike" and "spacelike" at all!
OK, but let's move on. Accordingly, in eqs (2.1) and (2.2.) they define the 2 different Galilean limits. First of all, at this point, they are not Galilean limits at all, because ##c## is still in both expressions.
But then in §§2.2/2.3 they look at the electromagnetic 4-current ##j_\mu= (c\rho,\mathbf{j})## and look at the 2 cases, essentially, ##j_\mu## either "mostly timelike" or "mostly spacelike". But the 4-current is a timelike 4-vector to start with! How and by what limiting process will that get transmuted into a "mostly-spacelike" 4-vector, on order to justify §2.3?
The authors criticize on p.234 the result referenced from Landau-Lifshitz, which "coincides neither with (2.7) nor with (2.14)", and remark that this does not correspond to any kind of Galilean limit. I have not studied those parts of Landau-Lifshitz yet (they seem to refer to some old edition, where the section numbering was different -- §3.10 in the most current Landau-Lifshitz editions does not exist).
Although the calculations are quite scarce, the math seems to be right, as it is not overall complicated, but I am also beginning to fail to see the point in the overall investigation, and I am struggling with the assumptions.
vanhees71 said:
#1 Of course you can NOT use "natural units" when you want to take the Newtonian limit, because if there is no "limiting speed", ##V##, there simply is no "natural unit" for velocities/speeds and also no natural way to measure time intervals and distances in the same unit. So before you take the limit ##V \rightarrow \infty## you have to fix space and time units.
#2 In Newtonian mechanics there is no such connection between space and time. The geometry is completely different: In Newtonian mechanics you have time and at each point in time a Euclidean space. If I remember the formalism right that's a kind of fiber bundle, while in special relativity you have a pseudo-Euclidean affine 4D manifold. I don't know, how to formally describe the limit ##V \rightarrow \infty## to deform the Minkowski spacetime to the Newtonian spacetime. I'm sure, there should be some literature about this somewhere.#3 In our context an example is the above quoted work by LeBellac and Levy-Leblond on the different "Galilean limits" of Maxwell's equations. After reading this paper I guess even the most anti-relativity sceptic should get convinced that relativity is the right foundation of electromagnetic theory ;-)).
#1:
I do agree with this statement. And now one specific paper comes back to my mind:
J.-M. Lévy-Leblond. “Nonrelativistic particles and wave equations”. In: Commun.
Math. Phys. 6 (1967), pp. 286–311
There, Levy-Leblond uses ##c=1## and -- let's skip the details -- concludes that by "linearizing" the Schrödinger equation as Dirac did with the Klein--Gordon equation, you end up with the Pauli equation, via a 4-spinor equation!
Now I don't want to open up another can of worms here, but essentially what Levy-Leblond arrived at in this paper is the "non-relativistic" limit of the Dirac equation in 4-spinor notation which can be found in any textbook, and there were no ##c##'s around because they have been eliminated by using natural units from the beginning. What IMHO the author failed to see in his approach is that -- by linearizing the Schroedinger equation using by the way the good old Dirac matrices which are dimensionless (!) -- you have to include a constant with the dimensions of "velocity" that simply does not exist in non-relativistic physics. You can't have a velocity scale in Galilei physics. By using ##c## explicitly in the formulae, the validity of the whole approach would have been made explicitly doubtful from the outset.
By the way: His main motivation was to show that spin by itself is not a relativistic effect (which is valid, because it isn't), but the method he chose to show this fails completely.
Addendum: I would like to take back my respective statement in posting #68 on using natural units as just one of many options.
#2:
https://www.physicsforums.com/threads/special-relativity-and-fiber-bundle.1016699/post-6650311
#3:
Oh yes. I am really struggling to interpret the paper.
Please do. This paper is not about taking a "Galilean limit" of standard SR. It is about a proposed alternative "Galilean" theory of electromagnetism, one which, to say the least, has not gotten any traction. Discussion of it definitely belongs in a separate thread (and to be honest, there isn't a lot to discuss given what I've said just above).
Please note that, as I said in response to @otennert just now, this paper is not (just) about taking "Galilean limits" of standard electrodynamics. It is proposing an alternative "Galilean" theory of electrodynamics.
Inspired by this article, there is an AJP article that proposes a new storyline to teaching relativity:
https://aapt.scitation.org/doi/10.1119/1.12239
“If Maxwell had worked between Ampère and Faraday: An historical fable with a pedagogical moral”
American Journal of Physics 48, 5 (1980);
https://doi.org/10.1119/1.12239
Max Jammer & John Stachel
(Further discussion along these lines should probably be moved to a new thread.)
No need from my side at this point. I actually share @PeterDonis's assessment.
Sure, but of course the Newtonian limit (for a mechanical situation) can be valid only in an inertial frame, where the bodies move with velocities much smaller than the speed of light, i.e., you'll get a good approximation to the relativistic dynamics only in such reference frames.
How do you come to that conclusion? There are both types of currents in nature: A "convection current", i.e., the current due to a single moving charge is of course timelike. In continuum-mechanical notation it's given by $$j^{\mu}=q n c u^{\mu},$$
where ##q## is the charge of the particles making up the fluid, ##n## the particle density as measured in the rest frame of the fluid cell (a scalar), and ##u^{\mu}## the normalized four-velocity (with ##u_{\mu} u^{\mu}=1##, using the (1,-1,-1,-1) signature).
Then there are conduction-current densities in wires, which are space-like. The charge density is close to 0 since there is the positive ion lattice in addition to the negative conduction electrons making up the current.
It's Eq. (2.23) on p. 224, and in my edition of Landau-Lifshitz's vol. 2 it's in Paragraph 24. That's indeed an approximation of the transformation law derived as an expansion in powers of ##1/c##, but indeed this doesn't lead to a transformation group and in this sense is not a consistent Galilean theory. Of course the paper also demonstrates that there is indeed no Galilean electrodynamics which is consistent with the phenomenology anyway.
Well, the question, whether there is a consistent Galilean electrodynamics is of some academic interest, but as the paper shows, it fails to describe the electromagnetic phenomenology right although of course there are good approximations to certain "non-relativistic" situations, e.g., the quasistationary approximations used to derive AC circuit theory.
