What Causes an Object to Float?
  • Thread starter Thread starter NeoScience
    Cause Float
Two main concepts determine whether an object floats: Archimedes' buoyancy principle and surface tension. While buoyancy is the primary factor, surface tension plays a role in specific cases, such as water strider bugs, which do not technically float but rather stand on the water's surface. The discussion highlights that an object's density relative to the liquid is crucial; if an object is less dense than the fluid, it will float. There is some debate over terminology, with participants noting that "floating" can have different meanings beyond buoyancy. Ultimately, the consensus emphasizes that buoyancy is the key principle, while surface tension can influence certain scenarios.
NeoScience
From what I gather so far, 2 main concepts determine if an object can float or not: 1) Archimede's buoyancy principle 2) Surface Tension.
Is the above reasoning correct? Are there any other concept?
I don't think surface tension has much to do with it.
Water strider bug has surface tension to hold it up.
I stand corrected.
I don't think the buoyant force would act on that bug would it?
If a body displaces fluid then I don't think surface tension would have much of an effect, for example in a boat.
Actually, it does. If you want to have some fun with water bugs, just put a few drops of dish detergent beside them. Poof... straight down. :biggrin:
An object that sits on top of a surface of a liquid due to surface tension is not floating. The word "floating" is referring specifically to buoyancy. It's right there in definition #1.
A water bug is standing on the water, not floating in it.
Oops... another terminology problem. :redface:
While 'buoyancy' refers to Archimedes, I always took 'floatation' to be a combination of various factors that keep an object from submerging. The vanes of a hydrofoil, for instance, are not buoyant... but they 'float' when an appropriate speed is achieved.
Where are you from, Danger (your profile says the Twilight Zone, so I'm guessing Canada?)? It could be geogrphical differences in word usage. I wouldn't say any non-displacement vessel floats when it is in that mode (including speedboats).
Yeah, it's probably regional. We use the term for lots of different circumstances, such as a car at the top of its suspension travel or a pool ball rolling too far. 'Skating' is used in the same context.
Well, wait - the word "float" has different definitions that don't all have to do with the concept of buoyancy - or even liquids. It has forty definitions. You can "float" an idea too, but that may be figuratively connected to the concept of buoyancy...
It is also a tool for polishing marble (36).
Maybe I'm just being pedantic - I'll ask a non-science type what they would say. Trouble is, I'll probably have to explain what a hydrofoil is...
Naw, don't put yourself out; I concede the point. I was just explaining my sloppy use of the word. :biggrin:
:cool: look, if an objects density(or volume,not sure which.Think it density.) is lower than 1, no matter what it is, it will float. its all about buoyancy:cool:
Doesnt it depend on the liquid it is trying to float in. The less dense object will float and the denser will sink, so since a brick is denser than water it sinks, likewise oil poured into water floats because it is less dense. I had always thought that is the main principle behind it. Is this correct?
In the case of the water bug or mosquito, it causes the "skin" of the tension layer of water to displace other water (small depressions in the water). I'm not sure how much of the "floating" for the water bug is due to displaced water and how much to just the surface tension.
