What Could Be Wrong with My Equilibrium Constant Calculation at 670K?
3 replies · 3K views
littlebearrrr
Estimate the value of the equilibrium constant at 670K for the following reaction: 2NO2(g)⇌N2O4(g)
ΔG°rxn = -RT*lnK
This should be an easy problem. But for some reason, MasteringChem won't accept it, so I'm wondering if I did anything wrong. Here's what I did:
1) Using tabulated free energies of formation, I obtained ΔG°rxn=-2.8 kJ=-2.8x10^3 J.
2) I then divided this by 8.314 J/molK multiplied by 670K (multiplied by -1, which cancels).
3) I took e^ of both sides. K=1.65
Anyone know what I'm doing wrong? Just a small hint will suffice. Thank you in advance :)
I get the same answer.
I would've used 8.315 J K-1 mol-1, but I don't think that's the problem here.
This is where things go bad! Could you show your calculation?
@ DrClaude and Chestermiller:
Sorry for the late response. Thank you for reviewing my post. To DrClaude: I forgot to account for the temperature in my calculations, as noted by Chestermiller. I calculated the std. change in enthalpy and entropy, and used the values to find ΔG^o at 670K. Then I plugged it into the equation from my first post to get a new answer of K=1.34e-5 (which turned out to be correct). Thank you both once again for looking at my post, and Chestermiller for offering that helpful bit of advice. :)
