What do Lorentz observer, Lorentz frame and spacelike vector mean?
  • Level: Graduate
  • Thread starter Thread starter Dixanadu
    Relativity Terminology
10 replies · 2K views · last reply
Dixanadu
Hi guys,
Can someone explain - as simply as possible - what the following terms mean?
1) Lorentz observer
2) Lorentz frame
3) spacelike vector
Thanks guys!
Yes I have read in books but 1) and 2) are often used without any explanation.
As far as 3) is concerned, I know what spacelike separation is, but I'm not sure what a spacelike vector is. 1) and 2) are more important for me right now!
I can't imagine what search phrase you are using but I put in "what is a lorentz frame" and got plenty of explanations.
Dixanadu said:
2) Lorentz frame
A Lorentz frame is an inertial frame (force-free motion is in a straight line at constant speed) using Einstein's synchronization convention.
Thank you for clarifying! Could you also tell me what a Lorentz observer is? or it is just someone in a lorentz frame?
I would have to see the context, although I could probably guess. It isn't a standard term that I am aware of.
In general I don't like the pedagogical obsession with observers. It gives the impression that relativity is about optical illusions.
By the way, everyone is "in" every frame. They may be "at rest in" or "moving in" any given frame, but either way they are "in" it.
Okay thank you. I hate to keep persisting but there is one more thing which I am a bit confused about.
What does it mean if something is Lorentz invariant? Say for example a typical lorentz transformation is given by [itex]\Lambda^{\mu}_{\hphantom{x}\nu}[/itex], and that we want to check if some object, say [itex]\phi[/itex], is invariant under it. How would you go about doing it?
A spacelike vector is a vector that points in a spacelike direction. If you think of a point in spacetime, and then consider nearby points, there will be a vector at the chosen point that points towards each of the nearby points. If a particular nearby point is spacelike separated from the chosen point, then the vector that points towards it from the chosen point is a spacelike vector.
As DaleSpam noted, context is important. My guess is that it means an observer who is at rest in a Lorentz frame.
