What do we exactly mean by space is expanding?
  • Context: Undergrad
  • Thread starter Thread starter Yashbhatt
    Expanding Mean Space
47 replies · 6K views
Yashbhatt
I know this question had often been asked on PF but I don't get them. What do mean when we say that space is expanding? I mean that space is no physical entity that can expand. Space is just (apparently) "nothingness". Please solve my confusion.
Astronomy news on Phys.org
the increase of space is simply an increase of geometric volume, that volume is filled with the contents of the universe.
You are right that space is not a physical entity, you oft read misnomers that imply that space has some physical property, however space itself does not. It has neither a physical property nor energy in and of itself.
But does it have the space to expand? Like if a balloon(yes, I am using the misleading balloon analogy) is expanding,
it is expanding in space? Then, what is space expanding into?
this is one of the best balloon analogies I've come across, it is written by another forum member Phind's. He covers that question in better detail than I
http://www.phinds.com/balloonanalogy/ : A thorough write up on the balloon analogy used to describe expansion
Space expanding is the same thing as matter contracting.
So instead of space expanding, just think matter contracting.
All we can measure is that the ratio galaxy_size/intergalactic_distance is getting smaller.
No, it is not. This has been discussed here on the forum many times.
"Expanding space" only happens outside galactic clusters. What would "matter contracting" mean? Why would it be different from "space shrinking"? Space does not expand or shrink and neither does matter. Things on the size of galactic clusters and larger just move farther apart withing the geometric framework that we call "space".
I suggest that you also follow Mordred's advice and read the link in my signature
Consider this example. Let there be two spaceships between Milky Way and some other galaxy. So, if space is expanding, then the two space ships should start moving away from each other even if they are set at a fixed distance from each other and are stationary with respect to each other. Will they move away?
Ok let's assume you have two stationary objects in a non gravitationally bound region. (expansion doesn't affect gravitationally bound objects)
then the answer is yes the volume of space between them will increase. So they will have an increase in distance between them, however they will not have gained any inertia, they will both remain stationary. The distance between them will simply increase. Expansion does not impart inertia
I assume by gravitationally bound you mean strongly bound objects like binary stars, galaxies etc. Otherwise everything is gravitationally bound as there are no limits to gravitational force.
No, that's not quite right. Certainly, you are correct in saying that there are no limits to gravitational force, but that does NOT imply that all objects in the universe are gravitationally bound to each other.
The Earth and the moon are gravitationally bound. The Milky Way and the Andromeda Galaxy are gravitationally bound. The Milky Way and the Bullet Cluster are NOT gravitationally bound. I think Your requirement of "strongly" bound is correct if you consider that your definition of what constitutes strongly bound is overly restrictive. Personally, I don't know if "strongly" bound even HAS a solid definition but "gravitationally bound" does ... it means, roughly, things that don't fly apart from each other.
I think one must be a little careful with this. Yashbhatt asked the question for two objects stationary relative to each other, which could be viewed as the Tethered Galaxy Problem of Tamara Davis et al.
Davies (abstract) said:
We use the dynamics of a galaxy, set up initially at a constant proper distance from an observer, to derive and illustrate two counter-intuitive general relativistic results. Although the galaxy does gradually join the expansion of the universe (Hubble flow), it does not necessarily recede from us. In particular, in the currently favored cosmological model, which includes a cosmological constant, the galaxy recedes from the observer as it joins the Hubble flow, but in the previously favored cold dark matter model, the galaxy approaches, passes through the observer, and joins the Hubble flow on the opposite side of the sky. We show that this behavior is consistent with the general relativistic idea that space is expanding and is determined by the acceleration of the expansion of the universe -- not a force or drag associated with the expansion itself. We also show that objects at a constant proper distance will have a nonzero redshift; receding galaxies can be blueshifted and approaching galaxies can be redshifted.
According to Mordred's (apparent) definition, one or both of the tethered ships must have had inertia relative to the Hubble flow, which is then diminished as they later joint the Hubble flow. In the epoch of non-acceleration of expansion, the said inertia could even have gone up (as they fall "through" each other), before joining the Hubble flow on the opposite side.
I don't understand the last part. Receding objects can show red shift and approaching objects can show blue shift?
yes motion has an influence on observations called Doppler effect. as objects approach there is a shift in frequency in light and sound waves (blueshift) as they recede there is a corresponding redshift
http://en.wikipedia.org/wiki/Doppler_effect
however redshift(blueshift) due to expansion not motion as per se. is called cosmological redshift
this article will explain the three types of redshifts in cosmology usage.
http://cosmology101.wikidot.com/redshift-and-expansion
They say the opposite of what you say, but qualified for the 'tethered case'. The detail explanation is in section III (p. 5) of the referenced paper. Essentially, a distant galaxy that would presently be "untethered" from our Galaxy could have a huge peculiar velocity towards us, with the resulting Doppler blueshift overwhelming the normal cosmological redshift.
actually I didn't even consider the tethered scenario, my main point is no momentum is imparted upon the galaxies due to expansion. in this article its covered by the statement.
"space is expanding and is determined by the acceleration of the expansion of the universe -- not a force or drag associated with the expansion itself"
still its a good point to be aware of the tethered scenarios
by the way Jorrie I tried posting the lightcone calc on the forum recently and it came up as an error what is the latest version link or is version 7 still the latest?
Jorrie off topic is version 7 the latest version of the lightcone calc?
I'm going to test the one off your signature
[tex]{\scriptsize\begin{array}{|c|c|c|c|c|c|}\hline R_{0} (Gly) & R_{\infty} (Gly) & S_{eq} & H_{0} & \Omega_\Lambda & \Omega_m\\ \hline 14.4&17.3&3400&67.9&0.693&0.307\\ \hline \end{array}}[/tex] [tex]{\scriptsize\begin{array}{|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|} \hline a=1/S&S&T (Gy)&R (Gly)&D_{now} (Gly)&D_{then}(Gly)&D_{hor}(Gly)&V_{now} (c)&V_{then} (c) \\ \hline 0.001&1090.000&0.0004&0.0006&45.332&0.042&0.057&3.15&66.18\\ \hline 0.003&339.773&0.0025&0.0040&44.184&0.130&0.179&3.07&32.87\\ \hline 0.009&105.913&0.0153&0.0235&42.012&0.397&0.552&2.92&16.90\\ \hline 0.030&33.015&0.0902&0.1363&38.052&1.153&1.652&2.64&8.45\\ \hline 0.097&10.291&0.5223&0.7851&30.918&3.004&4.606&2.15&3.83\\ \hline 0.312&3.208&2.9777&4.3736&18.248&5.688&10.827&1.27&1.30\\ \hline 1.000&1.000&13.7872&14.3999&0.000&0.000&16.472&0.00&0.00\\ \hline 3.208&0.312&32.8849&17.1849&11.118&35.666&17.225&0.77&2.08\\ \hline 7.580&0.132&47.7251&17.2911&14.219&107.786&17.291&0.99&6.23\\ \hline 17.911&0.056&62.5981&17.2993&15.536&278.256&17.299&1.08&16.08\\ \hline 42.321&0.024&77.4737&17.2998&16.093&681.061&17.300&1.12&39.37\\ \hline 100.000&0.010&92.3494&17.2999&16.328&1632.838&17.300&1.13&94.38\\ \hline \end{array}}[/tex]
kk its working now
It is an anachronism.
There are two ways to describe an expanding Universe (equally valid in General Relativity due to diffeomorphism).
1) Keep the coordinates of space fixed and the coordinates of particles change with time.
2) Let the space coordinates expand with time so the particles coordinates remain the same.
They are equivalent but in the 2nd example it is easier to talk about "expanding space" while in the first about "galaxies flying away from each other".
When you change coordinates in General Relativity you also change the gravitational fields. (Just like in the coordanates that move with a falling elevator there is no gravity). So in the 2nd one the particles feel no "force" while in the first one they experience a gravitational force between particles. So does space really "expand"? It depends on your coordinate system!
Your item 1 and your statement about it in the next sentence are contradictory. Galaxies flying away from each other IS what we see experimentally but "coordinates of particles change with time" is NOT what we see. Coordinates of GALAXIES (that are not in galactic clusters) change with time relative to each other, yes, but particles, no.
I meant "particle" in the mathematical sense of an object with coordinates. As such a galaxy is a "particle". I didn't meant elementary particles. Sorry for the confusion!
Yashbhatt said:
Can anyone explain how we deduced that space is expanding? I read that it was something related to the CMB on this site. http://astronomy.stackexchange.com/a/3654/1156(See the comments on mpv's answer).
Can anyone explain the reason in detail?
See here: http://en.wikipedia.org/wiki/Metric_expansion_of_space#Observational_evidence
There are several key things that support expansion. The redshifting of spectral lines from distant galaxies, the CMB, and the isotropic and homogeneous structure of the universe at the largest scales. In addition, expansion is also supported by helping explain the relative abundance of hydrogen and helium in the universe, as the prevailing cosmological model predicts the observed abundance of these elements to good precision.
Put simply, nothing in astronomy makes sense except in the light of universal expansion.
I read something like if it were we moving away instead of space expanding, then there would have been more dipole anisotropies in the CMB but what we observe is that we are almost stationary with respect to the CMB. I think that makes the most sense of all.
I'm not sure what you are trying to say here. The expansion of space certainly causes galaxies to end up with velocity relative to each other, and therefore momentum.
I don't really follow what you mean. Moving away from WHAT? We ARE moving away from every galaxy in the universe except for those in the local group, so what is it that we are not moving away from? We have a fairly modest velocity relative to the CMB but so does every galaxy in the universe despite the fact that they are all receding from each other, some faster than c. How does that fit with what you are saying?
No, it does not. Galaxies can be receding from each other faster than c, but there is no momentum involved. Metric expansion doesn't work like that.
Ok it is possibly the acceleration of the expansion rather than the expansion itself, analogously to how in the tethered galaxy paper the small galaxy remains at a fixed distance even after un-tethering in the constantly expanding scenario, but it recedes in the accelerating expansion scenario, and approaches in the decelerating expansion scenario.
edit: actually that seems a sensible result after all to me. Naively one would imagine that it was whatever happened in the beginning of the universe which drove the matter of the universe apart from each other, and that constant expansion would therefore correspond to "no extra force applied", while naively the accelerating/decelerating expansion would correspond to some "constant force applied".
See the link which I mentioned.
Perhaps you mean there are no forces that can be measured? Momentum is a relative measurement depending on reference frame. The definition of momentum is based on mass and relative velocity.
http://en.wikipedia.org/wiki/Momentum
Dependence on reference frame Momentum is a measurable quantity, and the measurement depends on the motion of the observer.
What aspect of the term "momentum" does not apply to two observers moving relatively to each other?
http://en.wikipedia.org/wiki/MomentumWhat aspect of the term "momentum" does not apply to two observers moving relatively to each other?
I think metric expansion is counter-intuitive, so I understand your point of view, but here's the thing: If recession were "motion" in the sense you mean, then distant galaxies actually WOULD be traveling faster than light relative to us. Relative motion of galaxies to the Milky Way does exist, but it is very small and it is not what you are talking about. Your definition of momentum is correct but your understanding of proper motion vs metric expansion is not.
The above statement is more me parroting back what I believe I have heard on this forum than it is any direct mathematical understanding of my own, so I'm open to the possibility that I'm wrong about this, but I don't see how. If I am I have no doubt that one of our more knowledgeable members will jump in and very politely slap me upside the head for being a dunce :smile:
Just look at the equation of momentum and you'll see what I mean. Are you seriously going to plug a faster-than-light speed into that equation? Again, that would imply ACTUAL PROPER MOTION greater than c and such a thing does not exist. That's why I don't see how I can be wrong about this.
