What does 150 N.M mean exactly?
  • Thread starter Thread starter captdiverdan
    Mean
The torque specification of 150 Newton meters (N·m) is equivalent to approximately 110 pound-feet (lb-ft) of torque. The correct conversion factor is 1 lb-ft = 1.356 N·m, which clarifies the misunderstanding regarding the conversion to 33.72 pounds of force. To achieve 150 N·m, one can apply 150 Newtons of force at a distance of 1 meter from the shaft, or adjust the force and distance accordingly. Proper notation for Newton meters is "N·m" or "N m".
  • Understanding of torque and its units (Newton meters, pound-feet)
  • Basic knowledge of force and distance relationships in physics
  • Familiarity with conversion factors between metric and imperial units
  • Awareness of proper scientific notation for units
  • Research the principles of torque and its applications in mechanical engineering
  • Learn about the conversion between metric and imperial units in engineering contexts
  • Explore the use of torque wrenches and their calibration
  • Study the implications of torque specifications in equipment design and safety
Engineers, mechanics, and anyone involved in equipment design or maintenance who needs to understand torque specifications and conversions accurately.
captdiverdan
If I have been provided information that a generator requires a torque/force is 150N.M to turn the drive shaft, what exactly does this mean??
I used an online conversion calculator and I came up with a conversion to pound-force of 33.72. Does this mean it will take approximately 34 pounds of force, such as indicated on a torque wrench, to turn the drive shaft?
Any help would be greatly appreciated.
Thanks
150 N-m
Attach a rod to the shaft sticking out 90degrees from the shaft axis.
Apply
150 Newtons of force on the rod at 1m from the shaft, or
75 Newtons at 2m, or
1 Nt at 150m, or
any combination of force and distance to give 150 n-m
Thanks for your help. Please consider that you are talking to a moron when it comes to this stuff. I guess my question is this;
Is 150Newton meters equivalent to approximately 110 pound-foot torque?
I want to use a piece of equipment that has the following specs- resistance force is 1.8R,and torque/force is 150N.M to turn the drive shaft.
What does this mean if you were asked to write about it in Engineering for Idiots?
Thanks for any help you can give.
Welcome to PF, captdiverdan! :smile:
Yes, 150Newton meters is equivalent to approximately 110 pound-foot torque.
Note that the conversion factor is not 33.72 as you wrote in the OP, but it is 1.356.
That is, 1 pound-foot torque = 1.356 Newton meter torque.
But I believe you already found this.
As a side note, this would (or should) not be written as N.M.
The proper way to write it is "N m" or "N·m". That is, with a lowercase m.
Thanks again for your help. This forum is excellent! What a wealth of information from individuals such as yourself.
You're welcome! :smile:
  • · Replies 24 ·
9K
13K
  • · Replies 20 ·
12K
  • · Replies 32 ·
