What Does a Spring Scale Read at Peak When Jumped On?
  • Thread starter Thread starter fender5791
    Scale Spring
The discussion centers on calculating the peak reading of a spring scale when a person jumps on it from a height of 1.2 meters. The spring compresses 0.50 mm under a weight of 740 N, leading to the determination of the spring constant (k) as 1.48 x 10^6 N/m. Participants confirm the use of the formula for kinetic energy (KE) and potential energy (PE) to analyze the scenario. The conversation emphasizes the application of energy conservation principles in this context.
  • Understanding of spring mechanics and Hooke's Law
  • Familiarity with energy conservation principles
  • Knowledge of kinetic and potential energy equations
  • Basic algebra for manipulating equations
  • Research the derivation and applications of Hooke's Law in real-world scenarios
  • Learn about energy conservation in mechanical systems
  • Explore the concept of spring constants and their significance in physics
  • Investigate the effects of different weights and heights on spring scale readings
Physics students, educators, and anyone interested in understanding the dynamics of spring scales and energy conservation in mechanics.
fender5791
If you stand on a bathroom scale, the spring inside the scale compresses 0.50 mm, and it tells you your weight is 740 N. Now if you jump on the scale from a height of 1.2 m, what does the scale read at its peak?
I'm guessing you use 1/2kx^2 but otherwise, I'm not sure.
Welcome to PF!
Hi fender5791! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
ok, so what is the value of k? :smile:
(and yes, you can use 1/2 kx2 later)
So would k be (740N)/(.0005m) = 1.48x10^6 N/m?
Yup! :biggrin:
Now use KE + PE = constant.​
Got it, thanks.
19K
9K
16K
