What does IERR mean in Fortran iostat?
  • Topic: Fortran
  • Thread starter Thread starter ydonna1990
    Fortran
9 replies · 7K views
ydonna1990
Fortran:
DO
      READ(11,'(a)',iostat=IERR)line
      IF ((line(1:2)/='--').and.(line/=' '))THEN
          READ(line,*,iostat=IERR) posinumber
          EXIT
      ENDIF
ENDDO
What is IERR? Is it related to error? I couldn't find any good answer researching online.
Thanks in advance
It means to store the result of the I/O operation in the variable IERR.
Code:
iostat=IERR, ERR=100
A more useful construct - this braches to the 100 line label on error. At line 100 test the value of the IERR variable to find the error number. You have to code the test somewhat like this:
Code:
100  IF (IERR .EQ. FOR$IOS_FILNOTFOU) THEN
          WRITE (6,*) 'File: ', FILNM, ' does not exist '
     ELSE IF (IERR .EQ. FOR$IOS_FILNAMSPE) THEN
        WRITE (6,*) 'File: ', FILNM, ' was bad, enter new file name'
    ELSE
    PRINT *, 'Unrecoverable error, code =', IERR
    STOP
    END IF
Some of the above example is FORTRAN implementation-specific - meaning those FOR$xxxxx constants are not guaranteed to exist for your flavor of FORTRAN. Eeee. I haven't looked at FORTRAN for a long time.
Code:
Code:
    ELSE
    STOP
    END IF
Thank you for your detailed reply. So that leads me to ask some more questions.
DO
READ(11,'(a)',iostat=IERR)line so I guess this means read the line 11 and test the IERR value there. What is this "(a)" for?
READ(line,*,iostat=IERR) posinumber I must also ask you what this "posinumber" means.
EXIT
ENDIF
ENDDO
You have what appears to be a 'code snippet' - meaning a piece of incomplete code - I do not know if your FORTRAN compiler will compile and run it. Too many years have elapsed...
1. it is a format specifier - this tells the compiler what kinds of input to expect
Note that there is a * and a (a) - two different flavors of input.
2. it is a variable, presumably it stores positive numbers - in coding your should give meaningful names to variables.
You are absolutely right. It doesn't run actually. I was given an assignment to fix this and make it run. I am really new to this so I am pretty much clueless. Do you think you can help me in private?
Ask your questions here, in general we don't help via private messaging because then others won't benefit from your questions and the subsequent answers.
Your first read is reading data from file 11 and placing it in the "line" variable. I think the "(a)" means read it as text ie alphanumeric data.
The "if" statement looks at the first two characters of the "line" variable to see if its "--" or two spaces and if NOT then it processes the second "read" statement
The second "read" statement is reading from whatever file the "line" variable now holds.
I would look at the file read by the first "read" statement to see what's inside it and piece that information together with what your program is doing to get an understanding of what's actually going on.
O.K. Thanks. What about this nCtrl here. I googled and found that it means node control. What does that mean?
DO jj=1,nCtrl
WRITE(30,*)g_best(jj)
ENDDO
do j=1,p_num
WRITE(520,*)ii,gf_best
enddo
ENDDO
Functionally, it determines how many times the DO loop will be executed. The WRITE statement will be executed nCtrl times. For any further "meaning" of that variable, you'll have to ask the person who wrote the code. Or it may be described by a comment somewhere in the code, or in any documentation that might have come with the code.
[added later] The name of the variable (nCtrl) has nothing to do with the operation of the loop, as described in my first two sentences above. What matters is the value (number) stored in that variable: 10, 25, 1634 or whatever. Whether that variable (and the number stored in it) indicates "number of controls" or "node control" or something else, depends on the overall purpose of the code and the intention of the person who wrote it.
