What does "minimum range of uncertainty" mean in QM?
1 reply · 2K views
Summer95
[/B]
The problem on where the photon will hit a screen, after passing through a single horizontal slit.
I know the wavelength, slit width, magnitude of momentum of incoming photon (calculated), and distance between screen and slit.
I just don't understand what the question is asking. What does minimum range of uncertainty mean?
If you send a bunch of photons through the slit, you'll get a spot on the screen. The problem is essentially asking you to find the size of that spot. There's a limit to how small the spot will be because of the uncertainty in the component of the photon's momentum parallel to the slit.
