What Does NaOH(aq) Mean?
  • Thread starter Thread starter AngelShare
    Confusion
12 replies · 3K views · last reply
AngelShare
What is this bolded part?
NaOH(aq)
Mind you, the bolded part is subscripted. I've seen that once before but don't remember reading anything about it.
AngelShare said:
Is it used for anything or is it simply there?
:smile: It indicates that the Sodium Hydroxide is dissolved in water.
What's that got to do with what I'm doing though?:bugeye:
Nyah, I figured that'd be at least a slightly amusing question.:smile:
it has important implications, depends on which experiment your doing.
Aqueous solutions are solutions in which the solvent is water.
An example is HCl. Most people refer to this as hydrochloric acid. But in reality it is only an acid if the gases are dissolved in water.
I'm balancing an equation-- NaOH(aq) + Fe(NO3)3(aq) -->
yeah, you can write out any important net ionic equations. The NaOH will actually be dissolved to Na+ and OH- right (and the same for iron II nitrate); except you might want to see if you've got any precipitates or anything else for a net ionic equations.
AngelShare said:
NaOH(aq)
Wrong. It should be the same size as rest of the text, and not bold nor italic.Borek
What do you mean, wrong? How could I be wrong by stating what I see right in front of me? O_o
And it isn't bold or italic...
I didn't mean you are wrong. I mean (aq) should be the same size as the rest of the text - if it is subscripted, book (or any other source you are looking at) uses it improperly.Borek
