What does <φ|² mean in quantum mechanics notation?
  • Thread starter Thread starter ultimateguy
8 replies · 4K views · last reply
ultimateguy
Which of the following is true?
[tex]<\phi|^2 = <\phi|\phi>[/tex]
[tex]<\phi|^2 = |\phi><\phi|[/tex]
Or does the order even matter?
I'm not entirely sure you can "square a bra" like that. But the order certainly matters.
Well I guess I should have said how do you multiply a bra by its complex conjugate, can you stick in the front or the back?
If you want a scalar, use option one. If you want an operator, use option two. Neither are called "squaring" -- and they're completely different things.
<phi|^2 = <phi|<phi| (pretty much meaningless)
<phi|phi> = 1 (or some other constant)
|phi><phi| = P_phi (an operator)
I don't think the tensor product is meaningless. One can build multi-particle states from it.
Ok well more specifically, my problem is turning this:
[tex](E_n - E_{n'}) <\phi_{n'}|X|\phi_n> = \frac{i\hbar}{m} <\phi_{n'}|P|\phi_n>[/tex]
into this:
[tex]\displaystyle\sum_{n'}^{} (E_n - E_{n'})^2 |<\phi_{n'}|X|\phi_n>|^2 = \frac{\hbar^2}{m^2} <\phi_n|P^2|\phi_n>[/tex]
using the closure relation. So basically everything is getting squared, but I don't know how to handle the part with the P and it's respective bra and ket. And what is confusing me as well are the two [tex]\phi_n[/tex]'s intead of a [tex]\phi_{n'}[/tex] in there.
into this:
Keep the following in mind, and give it a shot:
[tex]\langle \phi _1 | A | \phi _2 \rangle ^* = \langle \phi _2 | A^{\dagger} | \phi _1 \rangle[/tex]
If [itex]\{ \phi _i \}[/itex] is a complete basis, then [itex]\sum _i |\phi _i \rangle \langle \phi _i |= \mathbf{1}[/itex]
You want to multiply every complex number in the upper expression by its complex conjugate and then sum over n'.
PS: Before doing this, you might want to review the math a little bit. It seems you are unfamiliar with some of the basics of the algebra of a linear vector space.
For instance:
A bra is not a complex number (scalar) and hence, can not have a complex conjugate. It does, however, exhibit a dual correspondence to a ket living in a ket space that is dual to the bra space that your bra comes from.
