What does quantum spin actually define?
  • Level: High School
  • Thread starter saboo_tage
    Definition Spin
50 replies · 9K views · last reply
I looked through a number of the previous answers. I think i have a different view, although i think the conventional
ones made may not be so broad as my view...
To me, although one can think of spin, as the type of property one gets from a classical object spinning
(so, it might be thought of as so many revolutions per second),
yet there may be another way to consider spin..
To me, spin can also be viewed as a property of an electron, that we cannot really fathom.
I shall try to explain, and i hope my view, as expressed by me, is not way off the mark.
Spin put simply be a name with a property of having two inherent states (like the baryons and quarks, etc. have:
e.g. that can have a quantiized property, with two choices of the variable,or any combination of this property..
In this view, the "spin" of one half, means that the property can have two properties (yes or no, or up or down, or any other name,
as spin is like the other quantum properties, unfathomable, but
we can work with it, as having two choices (up or down), or a combination of these.
The spin,like other quantum properties can be in a superposition of the variables:eg.
rather than just being up or down, the electron can also be 1/2 up and 1/2 down, etc...
So, the electron's spin is more than the simple spin of classical objects.
Also, the spin # denotes the number of possible states the object can have: so the number
of states, if the spin state has a number say s, then the object can have 2s+1 states, so for
s=1/2, then there 2x1/2 +1 (2 states), so sping up or down. For a larger #, say g, the number
of different states would be denoted by 2g+1..
I looked at what i wrote, and my writings are not as well expressed as i would wish,
but not sure how would make them better.. If this view is 'wrong', I would be happy to
know how, so i can have this (above) view corrected..
ken, you've lost all of the geometric aspects of the spin. Up and down aren't just arbitrary labels for two states and shouldn't be replaced with blue state and green state. The spin is described by a geometric object called a spinor (for spin 1/2). If an electron is spin up, and you turn your head upside down, it will be spin down. (If you turn your head again a full 360, it will be spin up, but with an extra negative sign compared to the original.)
I think that I can visualise the classical approach to the recombination of hydrogen atoms; only three body collisions between hydrogen atoms and a third body to absorb the heat of combination are successful in forming the molecule when the the electron spins are in opposition. When the spins are similar the 3 entities fly apart.
Consider now the case of an electron attempting via Coulomb attraction to join an unfilled orbit of an ion. What prevents it from violating the Pauli principle?
If it's an unfilled orbit, then Pauli exclusion principle doesn't apply. If it's a filled orbit, then an extra electron will have to go into a different orbit.
I liked Ken's suggestion of a mysterious property of an electron.
Can you please explain to my simplistic way of thinking why the Pauli principle fails in this case.
It does not "fail". The Pauli principle says that two fermions may not have identical quantum numbers, so it says that you can have two electrons in different orbitals, or two electrons in the same orbital with different spins, but not two electrons in the same orbital with the same spins.
That's not right. There's no third body required or involved, the energy released by the reaction is not heat (although it may end up as heat eventually, and generally will if our reacting atoms are surrounded by matter). Most important, no matter what the initial state of the electrons we end up with the lowest orbital filled and the electrons having opposite spins - there is no "flying apart" if the spin are in opposition, they just change to allow the interaction to proceed.
You are trying to visualize this with classical thinking, imagining that the electron is a little object that moves around and can approach an ion, or that we could in principle try to force an electron with the wrong spin into an orbital.
However, from a quantum mechanical point of view, the two electrons are not separate particles. They are a single quantum system with a single quantum state, and none of the possible states have two electrons in the same orbital with the same spin. It's like the top and bottom of a rolling wheel; the entire wheel is moving and no matter how it moves the top and bottom will be opposite. It makes no sense to ask if we could make the top of the wheel be at one side while leaving the bottom at the bottom.
'Staff mentor' I am still puzzled by the idea ' that they just change to allow the interaction to proceed'. If that is the action what is the cause?
You are still trying to think of the two electrons as two separate things each with their own spin, so that something has to "cause" one of them to change its spin before the two of them can settle into the same orbital.
I know of no good classical analogies for multi-particle quantum systems (even the phrase "multi-particle" doesn't mean quite what it sounds like, because the word "particle" doesn't mean what it does in ordinary language). The closest I've been able to come up with is the example of a rotating wheel: If you think of two opposite sides of the wheel as two independent objects, it is very mysterious that somehow they are always moving in opposite directions. Once you realize that there is really just one thing there, the wheel, it makes more sense; if the two sides didn't always move in opposite directions it wouldn't be a wheel.
In other words a many-electron system is always entangled due to the fact that they are indistinguishable fermions and the state must be antisymmetric under interchanging any pair of the electrons (which defines what a fermion is). So it doesn't make sense to talk about any individual electron but you have to consider the entire system of many electrons as a whole.
It might be useful to look at orthohelium and parahelium. Orthohelium is helium in a state where both electrons have the same spin. Parahelium is helium in a state where electrons have opposite spin. (Normal ground state helium is parahelium.)
There are useful Grotrian diagrams here: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/helium.html
If electrons with the same spin were repelling each other with a "force", we'd expect the orthohelium states to have higher energies. Actually they have lower energies. There simply is no state of orthohelium where both electrons are in the 1s state. It's just not a state.
I am beginning to think that I am entering a Zeno paradox. Thus, at what distances does the system of wave functions begin their interaction and how close is this to entanglement?
Wavefunction, not wavefunctions. There is one wavefunction to describe both electrons.
I believe the frustration emerges from the pioneers choosing the only language they had available to hook new concepts to.
Spin implies something spinning.
Now we know more a new language could be adopted to better reflect our understanding. It would be very productive IMO.
Yes, and we have similar problems with the words "particle" and "observation" - both came into general use before the non-classical nature of the phenomena they attached to was fully understood.
It's a source of never-ending misery for the explainers as well as the explainees:smile:
Make a good Insights article, a lexicon of nonclassical objects and phenomenon.
Thanks for all the help offered. However, I am still puzzled by the distance over which two electrons can share a single wave function.
Basically, if the wavefunctions of the individual electrons don't overlap at all (or negligibly), you can treat them as separate wavefunctions. But if they interact at all, then you have to redo the calculation with a single wavefunction.
Then why not start coming up with a better language? Seems like you are in the perfect position to ignite such an endeavour. I've been lurking here for a while and it does get annoying to see the same endless arguments over unclear language and the misunderstanding it introduces. Just a suggestion, maybe a kind of moderated wiki of definitions would help.
It's not a simple matter as writing a glossary. It more like writing a functional programming language from scratch. Albeit a most unnatural language to boot.
The only good language is math, and the wave function of a many-body system (btw only very special cases of many-body systems can be described with a single wave function, namely only such, where the particle number is conserved; usually you need quantum field theory) is a function ##\psi(t,\vec{x}_1,\vec{x}_2,\ldots,\vec{x}_N)##, where ##N## is the number of particles. It's meaning is that ##|\psi|^2## is the probability to find simultanaeously a particle at ##\vec{x}_1##, ##\vec{x}_2##, ..., ##\vec{x}_N##. If the particles are indistinguishable, i.e., all their intrinsic quantum numbers (mass, spin, electric charges, lepton and baryon number) are the same, the wave function must also be unchanged or flip its sign whenever two of the particles are interchanged, i.e., ##\psi(t,\vec{x}_1,\ldots,\vec{x}_j,\ldots,\vec{x}_k,\ldots,\vec{x}_N)=\pm \psi(t,\vec{x}_1,\ldots,\vec{x}_k,\ldots,\vec{x}_j,\ldots,\vec{x}_N)##. For the plus-sign you have bosons, for the minus-sign you have fermions. Relativistic QFT as used to formulate the standard model you can show that all particles with integer spin are necessarily bosons and all particles with half-integer spin are fermions.
