What does the derivative of a function at a point describe?
The discussion revolves around the interpretation of the derivative of a function at a specific point, particularly focusing on its meaning and implications in calculus. Participants explore various conceptual understandings of derivatives, including their definitions, visual interpretations, and the relationship between a function's value and its rate of change.
  • Some participants propose that the derivative at a point quantifies the slope of the tangent line to the curve of the function at that point.
  • There is a suggestion that while a function has a specific value at a point, its values can vary at other points, leading to discussions about how to interpret the rate of change at a specific location.
  • One participant expresses confusion about the Wikipedia definition of the derivative, questioning how it can describe a rate of change at a point where the function has a fixed value.
  • Another participant acknowledges the common nature of the confusion surrounding the concept of derivatives and affirms that the initial description provided is fairly accurate.
  • There are inquiries about deeper insights into the concept of derivatives and whether there are additional interpretations beyond the basic definition.
  • Some participants mention the importance of understanding related concepts such as the chain rule and the Fundamental Theorem of Calculus as further steps in learning about derivatives.
Participants generally agree on the basic interpretation of the derivative as the slope of the tangent line, but there remains uncertainty and confusion regarding the implications of the derivative as a measure of rate of change, particularly in relation to fixed values of functions at specific points. The discussion does not reach a consensus on the deeper meaning of the derivative.
Participants express varying levels of understanding and comfort with the concept of derivatives, indicating that the discussion is influenced by personal interpretations and educational backgrounds. Some participants are seeking a more intuitive grasp of the derivative beyond formal definitions.
  • #31
Mark44 said:
For a function that is differentiable at a:
limh→0f(a+h)−f(a)h=f′(a)limh→0f(a+h)−f(a)h=f′(a)\lim_{h \to 0}\frac{f(a + h) - f(a)}{h} = f'(a)
For a function that is continuous at a:
limh→0f(a+h)=f(a)limh→0f(a+h)=f(a)\lim_{h \to 0} f(a + h) = f(a)
The important distinction between continuity and differentiability is that the latter is a stronger condition: every function that is differentiable at a is automatically continuous at a. A function that is merely continuous at a does not have to be differentiable there; for example, f(x) = |x|.
Right. Yes, I understand that. What I meant was that ##f'(a)## is defined as the limiting value of ##\frac{f(a+h)-f(a)}{h}## in the limit as ##x## tends to ##a## (##h## tends to zero). It is the limit that defines what the value of the derivative is at a given point, whereas for the continuity case, if ##f(x)## is continuous at ##x=a## then it's limiting value as ##x## tends to ##a## (##h## tends to zero) is equal to ##f(a)##, i.e. ##\lim_{h\rightarrow 0}f(a+h)=f(a)##. However, if ##f## is discontinuous at a point, then the limit ##\lim_{x\rightarrow a}f(x)## can exist, but it's limiting value won't be equal to ##f(a)##, as shown in your example.
What I was trying to highlight was that if the limit ##\lim_{h\rightarrow 0}\frac{f(a+h)-f(a)}{h}## exists, then by definition it's limiting value is ##f'(a)##, whereas the limit ##\lim_{x\rightarrow a}f(x)## can exist and have some limiting value, but this isn't necessarily equal to ##f(a)## (of course, if ##f## is continuous, then by definition it is equal), in other words, the value ##f(a)## is not defined as the limiting value of the limit ##\lim_{x\rightarrow a}f(x)##, but when it is equal to the limiting value of this limit, then the function is continuous at that point.
  • #32
Another possibility is that this limit doesn't exist at all, such as for f(x) = 1/x, with a = 0.
  • #33
True, good point.
Would the rest of what I put in my last post be correct? I think I'm understanding the derivative definition correctly now, would you say that's fair?
  • #34
Frank Castle said:
Undergraduate level (I'm ashamed to say). I understand how to use the derivative and its associated rules, etc. and I thought I understood intuitively what a derivative is, but now I'm not so sure, the description I read on Wikipedia has really thrown a spanner in the works for me (I'm not happy with simply accepting definitions when I learn maths, I want to have an intuitive idea of what the particular operation is describing). What the sticking point for me is, how do I make sense of the statement:
What exactly does this statement mean? Is it simply that although the function has a fixed value at that point the value of the function will in general be changing from point to point and the derivative evaluated at a particular point describes the rate at which its value is changing at that point in the sense that if a move away from that point (say ##x_{0}##) by a small amount ##\Delta x##, the value of the function ##f## will approximately change by an amount ##f'(x_{0})\Delta x##?
Correct.
  • #35
To give an alternate non-calculus viewpoint we can use a very old fashioned statement. The derivative is the slope of the line/plane that intercepts a curve/surface at exactly one-point. If the line isn't unique then the "derivative" isn't unique. It is presumed that the line is as short as necessary to avoid bumps. This leads into the whole idea that tangents/derivatives can be said to live in a different tangent space associated with a curve and not related to the space the surface/curve is defined in.
This is from some very old books that tried to avoid mensuration and wanted "intrinsic" definitions (I presume).
In addition: a derivation is defined by ## D(f(x)*g(x))=f(x)*D(g(x))+D(f(x))*g(x) ##
I add this to show that the derivative operator is a member of a broader class of operators having specific properties.
  • #36
Sorry, this definition does not work, consider the derivative of ## x^3 ## at ## x=0 ## or ## x^2sin(x^{-2}) ## (taken to be 0 at 0) at ## x=0 ##.
  • #37
But endeed, the full power of classical analysis and limit theory is not needed to understand differentiation. It can be done on a more elementary level. Unfortunately not too many people are aware of it.
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 53 ·
  • · Replies 46 ·
