What does the gradient mean in a given direction?
4 replies · 3K views
question dude
I've done the first part, but I'm stuck on the second paragraph of the question. Maybe I'm being stupid, I don't even understand exactly what is meant by, 'the level curve'.
I also don't quite understand the whole concept of directional derivative. When it says, 'the gradient in the direction making an angle A with the x-axis, how should I think of this? what does the gradient mean in this context?
because when its just a simple curve/line on an xy axis, I know what the 'gradient' means, it is literally how much 'y' changes per unit x along that curve/line. But when I'm told about a 'gradient in a direction', I'm confused.
hey, question dude! :smile:
question dude said:
… what is meant by, 'the level curve'.
think of the 3D graph, z = f(x,y)
you can make a 2D contour map showing the lines of equal height
those contours are the level curves :wink:
the directional derivative in the direction (cosθ,sinθ) is df(kcosθ,ksinθ)/dk
it's the rate at which f increases if you go along the line y/x = tanθ :smile:
You are supposed to show your work, confused or not (those are PF rules). I don't see how you can have done the first part (which involves directional derivatives) but then claim you do not understand directional derivatives. I would need to see your work in order to grasp what is going on.
Thanks a lot! I understand what's going on now. Before I was just plugging in the numbers without knowing the concepts properly.
Sorry about that, what I meant to get across, was that I understood the method in a sort of algorithmic way, but didn't understood the reason behind steps due to not understanding some basic stuff like 'level curve'. Anyway its sorted now.
