What does the wavevector \vec{k} mean?
  • Context: Graduate
  • Thread starter Thread starter mzh
    Mean
The wavevector \(\vec{k}\) is a crucial concept in wave physics, representing the spatial frequency of wavefronts in a given direction. It is defined as \(\vec{k} = [k_1, k_2, k_3] = [2\pi/\lambda_1, 2\pi/\lambda_2, 2\pi/\lambda_3]\) in three dimensions, where \(\lambda\) denotes the wavelength. The components of \(\vec{k}\) have units of reciprocal distance (1/m), ensuring that the dot product \(\vec{k} \cdot \vec{r}\) remains unitless. Understanding the wavevector is essential for analyzing various wave phenomena, including diffraction and interference, and is widely used in fields such as quantum mechanics and condensed matter physics.
  • Understanding of wave functions and their mathematical representations
  • Familiarity with the concept of wavelength and its units
  • Basic knowledge of vector mathematics and dot products
  • Awareness of wave phenomena in physics, such as diffraction and interference
  • Study the mathematical properties of wave vectors in quantum mechanics
  • Explore the relationship between wave vectors and wavenumbers in different media
  • Learn about the applications of wave vectors in condensed matter physics
  • Investigate the role of wave vectors in electromagnetic wave propagation
Physicists, engineers, and students in fields related to wave mechanics, quantum mechanics, and condensed matter physics will benefit from this discussion. It is particularly relevant for those involved in research or applications concerning wave phenomena and their mathematical descriptions.
mzh
Dear Forum
The wavefunction for a wave traveling in direction r can be written as
\psi ( \vec{r}, t ) = A \cos ( \vec{k} \cdot \vec{r} - \omega t + \phi ), where \vec{k} is the wave vector.
In one dimension, k = 2*\pi/\lambda, so is it correct to write the vector components of \vec{k}= [k_1, k_2, k_3] = [2\pi/\lambda_1, 2\pi/\lambda_2, 2\pi/\lambda_3]?
Thanks for any hints.
Hi mzh,
Yes, the vector specifies how many wavefronts one will measure in a unit length in each direction. (The geometric decomposition of a plane wave)
Note that you can you create a scalar wavenumber which may also use k as a variable name. One convention when doing that is to not use italics (where you would use italics for the vector).
http://en.wikipedia.org/wiki/Wave_vector
http://en.wikipedia.org/wiki/Wavenumber
PhilDSP said:
Hi mzh,
@phildsp, thanks. ok, if i get it right, this means the wavevector is a generalization of the wavenumber concept. ok. thanks.
The first half is correct. However, you cannot write [k_1, k_2, k_3] = [2\pi/\lambda_1, 2\pi/\lambda_2, 2\pi/\lambda_3] if [\lambda_1,\lambda_2,\lambda_3]=\frac{2\pi}{k^2}[k_1,k_2,k_3] is a vector in the direction of propagation and with the length λ.
A dot product between a position vector and a wave vector is well defined and easy to work with mathematically. That's why this notation is used. Dividing the position by a "wavelength vector" is not well defined, or rather the only sensible definition is via the wave vector. So rather than using some weird, indirect definition you just use the wave vector.
Note that this is true for all kinds of waves: Wave functions in QM, electromagnetic waves, acoustics, ... As soon as you have to deal with diffraction and interference you are much better off with the wave vector. Condensed matter physics is done almost exclusively in reciprocal space, i.e. writing things as function of the wave vector instead of real space position.
thanks quack for your comprehensive reply. however, I'm not sure if i understand all. the following i see, the dot product \vec{k}\cdot\vec{r} needs to be unitless. That means the unit of the components of \vec{k} should be reciprocal distance. But if what I wrote is wrong, then what do the components of \vec{k} look like?
Units of lambda are meters (or mm, Anstrom or whatever distance units you use)
Units of k are 1/m (1/mm 1/Angstrom ...), so each component of k has the same units.
Just as \vec{r}. Each component has units meters.
It seems the definition of wavenumber that Wikipedia gives is a specific wavenumber scalar that could be called
k_{mag} = \sqrt{k_x^2 + k_y^2 + k_z^2}
where k_x is the spatial frequency in the x dimension such that
k_x = \vec{k} \ \cdot <1, 0, 0>
k_y = \vec{k} \ \cdot <0, 1, 0>
k_z = \vec{k} \ \cdot <0, 0, 1>
@Phildsp/quack: Ok, thanks. So I see it this way that the wavevector is a "generalization" of the wavenumber.
Yes, it combines the wave number and the direction of propagation.
The wave vector is an extremely useful concept in wave physics. Taking time to understand it properly will save you headaches later on :-)
