What does this equation for an electrochemical cell mean?
The discussion revolves around the interpretation of an electrochemical cell reaction involving cerium and iodine, specifically the Standard Gibbs free energy calculation and the physical setup of the cell. Participants explore the nature of the electrodes and the reactions occurring in the cell, contrasting it with more traditional examples like the zinc-copper cell.
  • One participant expresses frustration over the absence of solid metals in the cerium-iodine cell reaction compared to the zinc-copper example.
  • Another participant suggests that not all electrode reactions require a solid conductor, citing the hydrogen electrode as an example, and proposes the presence of an inert metal conductor in the cerium-iodine cell.
  • It is noted that the inert electrodes would facilitate electron transfer without participating in the reaction themselves.
  • One participant describes the reduction of cerium(IV) ions at the cathode and the behavior of iodine ions at the inert electrode, suggesting that iodine may form adsorbed species before reacting further.
  • There is mention of the role of water of solvation and the potential impact of ligands or additives on the electrochemical interactions in the cell.
Participants generally agree on the presence of inert electrodes and the nature of the reactions occurring, but there are nuances in understanding the specifics of the iodine reaction and the effects of solvation and additives, indicating some unresolved aspects of the discussion.
Participants acknowledge that the example discussed may be limited to simple cerium salts and that the addition of ligands could significantly alter the electrochemistry, highlighting the complexity of the interactions involved.
zenterix
Consider the electrochemical cell reaction given by
$$\mathrm{2Ce^{4+}(aq)+3I^-(aq)\rightarrow 2Ce^{3+}(aq)+I_3^-(aq),\ \ \ \ \ E^\circ_{cell}=+1.08V}$$
Item (a) of problem 1 of a chapter on "Galvanic Cells" asks us to calculate the Standard Gibbs free energy for this cell reaction.
I can do the calculation, but I am frustrated by the following.
The entire chapter focused on the electrochemical cell
$$\mathrm{Zn(s)|Zn^{2+}(aq)||Cu^{2+}(aq)|Cu(s)}$$
with explanations for what this means in terms of a physical setup. Namely, solid metals immersed in ionic solutions, connected by a conductor and a salt bridge.
The equation
doesn't have any solid metals in it.
It appears we have the redox half equations
$$\mathrm{2Ce^{4+}(aq)+2e^-\rightarrow 2Ce^{3+}(aq)}$$
$$\mathrm{3I^-(aq)\rightarrow I_3^-(aq)+2e^-}$$
Is this correct?
What does this cell look like in real physical terms?
Here is my guess.
Not all electrode reactions include a conducting solid as a reactant or product.
A hydrogen electrode, for example, includes hydrogen gas and aqueous hydrogen cations.
There is, however, a chemically inert metallic conductor present, such as an unreactive metal or graphite or platinum (in the case of a traditional hydrogen electrode), which serves to carry electrons into or out of the electrode compartment.
So in the case of the cell reaction involve cerium and iodine, I suppose there would be something similar, ie some inert metal conductor present.
Perhaps we would have
$$\mathrm{Pt(s)|Ce^{3+}(aq),Ce^{4+}(aq)||I^-(aq),I_3^-(aq)|Pt(s)}$$
However, we don't have gases. Instead we seem to have two solutions, one at each inert metal, each containing two different ions.
The oxidized and reduced species are both in the same phase.
Not clear though how this works exactly.
Since ##E^\circ_{\text{cell}}## is positive we have electrons moving spontaneously from the electrode with the iodine ions to the electrode with the cerium ions.
In the case of the zinc/copper example, I understood that we had solid zinc being oxidized and going into solution and copper ions being reduced and becoming solid copper.
In the case of cerium and iodine, what happens exactly?
Pt act as an inert electrode (and possibly catalytic in some case) and simply connects the circuit.
Yes, you are correct, there would be inert electrodes of some sort
Physically, Cerium(IV) ions get close enough to the cathode that an electron can hop from the cathode to the cerium ion, reducing it to cerium(III). The cerium(III) ion then floats away in solution.
The iodine is likely slightly more complicated; each I- ion will go to the inert electrode and give up its electron, but you're not going to get a free iodine atom floating off into solution. Probably you get a couple iodine atoms adsorbed to the electrode until they can meet up with each other to form the I2 molecule, which will then react separately with an additional I- ion to form the triiodide.
There's also water of solvation in all of these cases which can affect how the ions interact with the electrodes in subtle ways. In a real battery, various ligands or other additives might be added to either solution to make the interaction of the reactants with the electrode more efficient, or prevent various possible side reactions.
To be add, the addition of ligands will likely drastically change the electrochemistry. The example in the original post is only (safely) applicable to simple Cerium salts.
9K
