What engineering field uses the most Physics?
Engineering fields are deeply rooted in physics, with disciplines like Mechanical, Electrical, and Civil Engineering deriving from classical mechanics. While physics can be challenging, it provides a foundational understanding that enhances engineering studies. Students are encouraged to take physics courses first, as they clarify engineering concepts and applications. The distinction between physics and engineering lies in their goals: physics seeks to advance scientific knowledge, while engineering focuses on practical applications for improving human life. Ultimately, exploring introductory engineering classes can help students identify their interests and strengths in these interconnected fields.
Scramble
I am interested in Classical Mechanics and the Universe
If you can handle the math, go Physics first, then EE.
Bob S (a retired physicist)
I was kind of worried about the difficulty of Physics, engineering or computer science seem to be ever so slightly easier...
Engineering Physics i think is the answer.
my school doesn't offer that, except to graduate school students
Mechanical Engineering
classical physics at its finest.
What are you afraid of? If you are interested in physics, study physics.
How can this question best be approached? All of our usual engineering disciplines are basically derived from Physics: Mechanical Engineering, Electrical & Electronic Engineering, Civil Engineering, Aeronautical, Aerospace Engineering, Nuclear Engineering - - - none of these would exist without Physics. (You might look at Systems Engineering and Chemical Engineering a bit differently, but not totally. Remember, Chemistry itself is based in Physics - - - and you might look at physics as based in Mathematics.) The distinction between Physics and the Engineering disciplines is the intended result. Physics is aimed at advancing the science itself; Engineering is aimed at using that science for the advancement of the living conditions of humanity. As such, the tools (mainly math) used by the two communities is slightly different. One leans toward those that lead more toward deriving and explaining the science, and the other leans toward those that best apply it (in other words, shortcuts). In the end, they are essentially the same. An Engineer can work in the fields of Physics and a Physicist can perform as an Engineer - - - though they occasionally take snipes at each other - - - mostly in jest. Finally, I agree with one of the earlier insertions. If you have the time (most engineering students probably don't), by all means take General Physics first. It will make most engineering disciplines clearer. (The same, by the way, goes for Chemistry - - - it is easier if Physics is taken first. The problem here is that most students find Physics the more difficult, probably because it requires us to unlearn some of our youthful notions.)
KM
Maybe you could tell more about your situation. I might take a guess you are interested in physics and technology, but have found an actual physics class to be rather difficult. So you'd like to pursue an engineering degree because of your interest in technology.
But I am only guessing here. Also, are you supposed to declare a major soon?
You may just have to take several introductory engineering classes to find out which interests you the most. If I had to, I would suggest mechanical, electrical, and chemical engineering, since they are rather diverse. After 1 semester of introductory classes in those 3, you'll have a much better idea of which interests you the most.
