What engineering field uses the most Physics?
The discussion revolves around which engineering field utilizes the most physics, exploring various engineering disciplines and their relationship to physics. Participants share personal experiences, preferences, and insights into the educational paths related to physics and engineering.
  • Some participants suggest that Engineering Physics is a strong candidate for the field that uses the most physics.
  • Others argue that Mechanical Engineering exemplifies classical physics applications.
  • One participant emphasizes that all engineering disciplines, including Electrical, Civil, and Aerospace Engineering, are fundamentally derived from physics.
  • Another viewpoint highlights the distinction between physics and engineering, noting that physics aims to advance scientific understanding while engineering focuses on practical applications for improving living conditions.
  • Concerns about the difficulty of physics compared to engineering and computer science are expressed, with some participants suggesting that introductory courses in engineering may help clarify interests.
  • There is a suggestion that taking General Physics before pursuing engineering could enhance understanding of engineering concepts.
Participants express a range of opinions on which engineering field uses the most physics, with no consensus reached. Some agree on the foundational role of physics in engineering, while others emphasize different fields or personal experiences.
Participants mention varying levels of difficulty in physics compared to engineering and computer science, indicating that personal experiences and educational environments may influence perceptions of these disciplines.
Scramble
I am interested in Classical Mechanics and the Universe
If you can handle the math, go Physics first, then EE.
Bob S (a retired physicist)
I was kind of worried about the difficulty of Physics, engineering or computer science seem to be ever so slightly easier...
Engineering Physics i think is the answer.
my school doesn't offer that, except to graduate school students
classical physics at its finest.
What are you afraid of? If you are interested in physics, study physics.
How can this question best be approached? All of our usual engineering disciplines are basically derived from Physics: Mechanical Engineering, Electrical & Electronic Engineering, Civil Engineering, Aeronautical, Aerospace Engineering, Nuclear Engineering - - - none of these would exist without Physics. (You might look at Systems Engineering and Chemical Engineering a bit differently, but not totally. Remember, Chemistry itself is based in Physics - - - and you might look at physics as based in Mathematics.) The distinction between Physics and the Engineering disciplines is the intended result. Physics is aimed at advancing the science itself; Engineering is aimed at using that science for the advancement of the living conditions of humanity. As such, the tools (mainly math) used by the two communities is slightly different. One leans toward those that lead more toward deriving and explaining the science, and the other leans toward those that best apply it (in other words, shortcuts). In the end, they are essentially the same. An Engineer can work in the fields of Physics and a Physicist can perform as an Engineer - - - though they occasionally take snipes at each other - - - mostly in jest. Finally, I agree with one of the earlier insertions. If you have the time (most engineering students probably don't), by all means take General Physics first. It will make most engineering disciplines clearer. (The same, by the way, goes for Chemistry - - - it is easier if Physics is taken first. The problem here is that most students find Physics the more difficult, probably because it requires us to unlearn some of our youthful notions.)
KM
Maybe you could tell more about your situation. I might take a guess you are interested in physics and technology, but have found an actual physics class to be rather difficult. So you'd like to pursue an engineering degree because of your interest in technology.
But I am only guessing here. Also, are you supposed to declare a major soon?
You may just have to take several introductory engineering classes to find out which interests you the most. If I had to, I would suggest mechanical, electrical, and chemical engineering, since they are rather diverse. After 1 semester of introductory classes in those 3, you'll have a much better idea of which interests you the most.
