What is this mysterious mechanical device found in an Air B&B cottage?
  • Thread starter Thread starter sophiecentaur
The mechanical device found in the Air B&B cottage is identified as a "Hand Yarn Twist Tester," specifically designed for measuring the number of twists in spun yarn. It operates by clamping the yarn and applying a constant tension while the spindle is turned to reverse the twist, allowing for precise measurement of twist per length. The device features a gear mechanism with a 20:1 ratio and a worm gear with a 60:1 reduction, indicating its intricate design. The discussion highlights the importance of identifying the correct terminology and industry context for accurate identification of such instruments.
  • Understanding of yarn testing methods
  • Familiarity with mechanical devices and their functions
  • Knowledge of gear ratios and their implications in machinery
  • Basic principles of textile engineering
  • Research "Hand Yarn Twist Tester" and its applications in textile engineering
  • Explore the operating procedures for yarn testing instruments
  • Learn about gear mechanisms and their applications in mechanical devices
  • Investigate modern alternatives to traditional yarn testing methods
This discussion is beneficial for textile engineers, mechanical engineers, and anyone involved in yarn production or testing, as well as collectors of antique measuring instruments.
sophiecentaur
I found this on a dusty shelf in an Air B&B cottage. It looks 'mechanical' so do any of you Mech Engs recognise it? It looks like it could be some sort of tensometer ??
Maybe it was used for winding under-thread, with a preset tension, onto the bobbin of a sewing machine.
Can you read anything on the scale?
The gear mechanism is interesting.
The top device has a screw clamp at its business end and has a ratio of 20:1-ish with the crank.
The bottom device is more mysterious and has a ratio more like 1:20-ish with the crank,
but I can't even tell where the business end of it might be.
Maybe ask the owner?
[edit]
(has been moved to following post with minor addition to 'graduations'.)
[/edit]
Need more photos/details, can't see enough of the 'bottom device' to tell what the crank ultimately turns.
The Red strip below the crank mechanism on the right has some printing on it. Using Photoshop, I can just make out the first 3 characters as 'Z&U', although the '&' is backwards from the American character; that may provide a clue to country-of-origin.
Too bad those are .JPG images. (darn digital cameras!)
Pure speculation here!
Tensile strength tester? Stretchability of a yarn?
There are graduations on the arc - the 2nd-from-left seems to be either '9' or '2'.​
The 'attachments' on the left may mount on the hub of the pointer to supply a torque (note the protrusion at 10 o'clock on the pointer hub)​
Cheers,
Tom
The object was high up on a shelf and I couldn't get it down to see any detail. That long vertical arm is obviously for magnification.
I have returned from the cottage and can't approach the owner (it was such a dump, aamof, that I don't really want to talk with him).
I was hoping that someone would just look at the image and say "Ahh, that's an XYZ machine". But speculation on flimsy information can be fun (one of PF's styles of choice.).
But it also has a worm gear with something like a 60 to 1 reduction, possibly for a counter.
I think we have a winner with that
Too many common points
Kind of an early or cheap piece, maybe?
"Hand Yarn Twist Tester", made in China ...
https://www.ebay.com.au/itm/325117213756?
https://www.ebay.com.au/itm/164749199309?
https://textilelearner.net/twist-measurement-of-yarn/
The OP instrument does not test tension, it measures the small change in length of a spun yarn as it is twisted. Procedure: The spindle counter dials are set to zero. The yarn to be tested is clamped at the spindle and at the length gauge, with a weight beyond the length gauge, to apply a constant tension. The spindle is then turned to remove the twist, which lengthens the yarn, but turning is continued until the length gauge shows the yarn length has reduced again to the same reading as initially set, (but with the twist now reversed). Half that spindle turns counter reading is the number of twists per length tested. No magnifying glass is needed to examine the yarn to determine the average point of zero twist at different positions along the sample.
  • Love
Well dang mah hide! Like I said, there's always someone who knows the answer to any question I choose. Thanks a lot @Baluncore .
The prize should go to @Rive who found the "M. Defraine, old thread and yarn precision instrument, pull meter, yarn tensioner"; that was wrongly described as a tensioner by the seller.
That gave me a lead to search the web for the current technology, then google images to find the operating procedure for the indicator type instrument as shown in the OP.
Not really. On my own, I've been searching for antiques related to torsion wires :doh:
Without you identifying the industry first (right at the start!), it was completely hopeless for that 'M.Defraine' to pop up.
You guys are like when you're walking with your dog in the park and it spots a squirrel. (Correction "We guys") :smile:
Think yourself lucky, that you are not the squirrel.
  • Haha
  • · Replies 16 ·
  • · Replies 42 ·
