What exactly does negative permittivity mean?
The discussion centers on the concept of negative permittivity in metamaterials and metals, highlighting that metals exhibit negative permittivity at frequencies above their plasma frequency. It is established that negative permittivity results in the electric displacement vector D and electric field being 180 degrees out of phase. The phenomenon is explained through the harmonic oscillator model, where the electric polarization P is influenced by the electric field. Relevant articles, including "Physics of negative refractive index materials" (2005), are recommended for further understanding.
  • Understanding of metamaterials and their properties
  • Familiarity with the concept of plasma frequency
  • Basic knowledge of harmonic oscillators in physics
  • Awareness of electric displacement and electric field relationships
  • Research the harmonic oscillator model in the context of electric polarization
  • Explore the implications of negative permeability in metamaterials
  • Investigate the relationship between frequency and negative permittivity in metals
  • Read the article "Physics of negative refractive index materials" (2005) for deeper insights
Physicists, electrical engineers, materials scientists, and anyone interested in the properties and applications of metamaterials and negative permittivity phenomena.
spikethecake
Hi, this is my first time posting on these forums but I've been reading them for a while.
I was having a look at metamaterials and it mentioned that metamaterials had negative permittivity and negative permeability. I also found that metals naturally had negative permittivity; though I am still unsure whether this is always the case or just at certain frequencies.
I'd also like to ask why this occurs and what it means exactly; by being negative, is the field refracted in the opposite direction?
Good question, may I join to you, I wonder too what is the answer :smile:
i am wondering too. following the equation C=dQ/dV, is the charge repelled or the field? what is the phenomena happened in most metals?
Some may response with the collision frequency, i guess. help, please?
Negative pemittivity means that the electric displacement vector D and electric field are180 degrees out of phase, i.e. antiparallel.
This occurs in some region above a resonance. In a metal, the resonance frequency is formally zero and the region of negative permittivity extends up to the so-called plasma frequency.
You can get an easy picture of what is going on if you model the electric polarization P (~D) as a collection of harmonic oscillators of frequency ##\omega_0## which are driven via a coupling to the electric field ##\sim E_0 \sin(\omega t)##, i.e.
##1/2m \frac{d^2 x}{dt^2}+\gamma \frac{dx}{dt} +k/2 x^2 =e E_0 \sin(\omega t)##
here,x is the coordinate, m is the mass, e the charge of an electron, and k the spring constant, ##\gamma## the damping.
You can solve this equation analytically and obtain x(t) as a function of frequency.
DrDu said:
Negative permeability means that the electric displacement vector D and electric field are180 degrees out of phase, i.e. antiparallel.
This occurs in some region above a resonance. In a metal, the resonance frequency is formally zero and the region of negative permeability extends up to the so-called plasma frequency.
Thanks DrDu. So what happen at even lower frequency region in the metal that cause an increase in negative permittivity followed by a decrease in negative permittivity e.g. well-shaped pattern of e' as a function of frequency? i guess i'd figured out the decrease in negative permittivity as the frequency approaching the plasma frequency. just that I don't understand why is it having an increase negative permittivity at lower frequency.
DrDu said:
The article shows the "electrical engineering" point of view of negative refraction. Interesting is also the article by Agranovich and Gartstein, which discusses the phenomenon as an effect of spatial dispersion:
http://iopscience.iop.org/1063-7869/49/10/R03
Thank you DrDu.
I was wondering where can we find reported data with negative capacitance as a function of frequency for conductors. It is quite hard to get a data comparison for common metals.
Does anyone got any idea?
  • · Replies 30 ·
9K
  • · Replies 20 ·
  • · Replies 19 ·
