What Flexible Sealing Element Can Withstand 500°C and Allow Linear Motion?
The discussion centers on identifying a flexible sealing element capable of withstanding temperatures of 500°C while allowing linear motion. The context involves a project requiring a sealing solution that prevents particles or liquids from passing behind a sheet metal plate in a high-temperature environment.
  • One participant seeks a sealing element that can endure high temperatures and allow linear motion, emphasizing the need for minimal clearance between the moving object and the seal.
  • Another participant questions whether the seal needs to withstand fluid pressure or simply provide a physical barrier against splashes.
  • A subsequent reply clarifies that the seal is intended only for splash protection.
  • One suggestion proposes using opposing paint brushes as a sealing mechanism, referencing their use in automotive emergency brakes, while noting the challenges of material oxidation at high temperatures.
  • A further consideration is raised about the possibility of a movable seal that could follow the motion of the object, suggesting that this might simplify the design requirements.
Participants generally agree on the requirement for splash protection rather than pressure containment. However, there is no consensus on the best approach or material for the sealing element, and multiple ideas are presented without resolution.
Participants express concerns about material properties at high temperatures, including oxidation and mobility of materials. The discussion does not resolve the specific material choices or design constraints.
Engineers and designers working on high-temperature applications, particularly those involving sealing mechanisms in mechanical systems.
yanikomer
I am working on a project where I need a high temperature sealing element. You can see the system in the attachment.
My moving object is moving linearly in a motion slot which is constructed on a sheet metal plate. But the surrounding temperature in this process is 500 C degree and there must be a flexible sealing element which does not let any particules or liquid material (oil etc.) to the behind of the sheet metal plate. As you see in the photo, I want the clearance between moving object and the sealing element as small as possible.
Does anyone know such a flexible sealing element that I can use in such a high temperature level and it also allows the motion of the moving object?
Thanks
yanikomer
Is this seal meant to hold the pressure of a fluid? Or does it just need to provide a physical barrier, e.g., splash protection?
Yeah it is just for splash protection.
If it's just splash protection, something set up like opposing paint brushes might work out pretty well. You see guards like that on the lever-style emergency brakes of some cars. You're a bit below the melting point of Aluminum, so it might be an option. Problem is, you're going to be hard-pressed to find a good metal that won't oxidize over time, if this is in an oxygen-containing environment. 500C is hot, and a lot of things are mobile at that temp.
What about a movable seal? In the drawing you have, it specifies that the seal be a stationary thing. Does it have to be? I think it would be much easier to have the seal move along with your object, if it's guarding something behind it. It just depends on the other parts of your design spec.
  • · Replies 152 ·
13K
22K
11K
