What geometry theorem is used in this figure?
The discussion revolves around identifying the geometry theorem applicable to a figure involving a triangle, specifically regarding the relationship between the sides and angles. Participants explore whether the triangle is a right triangle and how various theorems, including the angle bisector theorem, might apply to the given ratios of the sides.
  • Some participants question whether the triangle in the figure is a right triangle, suggesting that the Pythagorean theorem does not hold with the given dimensions.
  • Others assert that the triangle is not a right triangle and provide calculations of angles using the law of cosines, indicating a specific angle measurement.
  • A participant proposes that the ratio of the areas of the triangles is equal to the ratio of their bases, leading to a relationship involving the sides of the triangle.
  • Some participants reference the triangle angle bisector theorem as relevant to the discussion, although there is uncertainty about its application and proof.
  • Several comments express frustration with the clarity of the original drawing, suggesting that it may have contributed to misunderstandings about the problem.
  • There are conflicting views on the accuracy of the drawing, with some insisting it is correct while others argue it is misleading.
Participants do not reach a consensus on whether the triangle is a right triangle or the correctness of the drawing. Multiple competing views remain regarding the application of theorems and the interpretation of the figure.
Some participants note that the drawing lacks clarity, which may affect the understanding of the problem. There are also unresolved questions about the assumptions made regarding the triangle's properties and the application of theorems.
barryj
What geometry theorem is used to be able to state that 8/4 = x/6 ??
Mathematics news on Phys.org
Is the angle at the lower left corner a right angle?
If x=12 is the hypotenuse,
then the suggested right triangle doesn't satisfy the Pythagorean theorem
since 8^2+(4+6)^2 \neq 12^2.
Something is not correct.
Is this a right triangle? If so, the statement is false.
@barryj as you should have figured out by now from the comments above, your figure is very vague. Please draw a more detailed/specific graphic of what you are trying to figure out.
It is not a right triangle. I worked backwards assuming x is 12 and then calculated the angles that are equal and they are, 27.8858 deg (using law of cosines). The angle that looks like a right angle is in fact 82.8192 deg. I know there is some geometry theorem that stats what I have shown but I hve not found it. It is some sort of triangle bisected vertex theorem? The numbers 8,4,6, and 12 are correct.
The ratio of the areas of the two triangles is the same as the ratio of their bases because the height to them is the same. So it is 6/4. On the other hand, the heights to the slanted sides( the x and 8) are also equal because they start from the angle bisector. So the areas of the triangles also have ratios as those sides i.e. x/8. Thus 6/4=x/8.
What exactly have you shown? That there exists some triangle that satisfies that ratio?
I was told that the answer was 12. I just wanted to see if this was true. The theorem is called the triangle angle bisector theorem.
martinbn said:
https://en.wikipedia.org/wiki/Angle_bisector_theorem
I think the the prove I wrote is more natural, but then it may seem that way to me because that's what came to mind first.
"So the areas of the triangles also have ratios as those sides i.e. x/8. Thus 6/4=x/8." It is not obvious to me that this is true.
I think the proof of this is probably the same or closely related to the proof of the angle bisector theorem. I looked at those proofs in the link. If any of those proofs are obvious to you, then you are a smarter man than me. ;-)
My geometry book does have the proof of the triangle angle bisector theorem but it is a bit complicated. I may, I repeat, may try to understand it at a later time. Right now I will just remember the theorem.
The drawing is very, very poor. You're very lucky that people were able to figure out your question.
  • You should not draw a right triangle if the triangle is not supposed to be right.,
  • As I understand it, the line from the top vertex to the base divides divides the base into 4 and 6. The tick mark you drew to the right of the 4 and to the left of the angle bisector is irrelevant.
If you want to do well in geometry, you need to be more careful in your drawings. If you want help - not just in geometry, but in life - you need to make it easy for people to help you. Making them work hard because you didn't spend the time to express yourself clearly is ineffective. (Some might even say disrespectful.)
You are wrong. The drawing is correct. You should NEVER assume things. If the drawing does not say it is a right triangle, then do not assume it is.
  • Wow
  • Sad
Good luck in life with that attitude.
Well, when this problem was presented to my student ( I am a tutor) he worked it immediately. I did not recall the theorem he was using and this is why I posted on this forum. In fact, it took me a while to find the theorem in my geometry book as I did not know the proper name for it. I am surprised that the people on this forum had an issue with my question. I would have expected an answer like, "this is the triangle angle bisector theorem" but did not get it. Anyway, my attitude3 has been a benefit to me for many years.
This is a more accurate drawing of the triangle: I would not have drawn it as right.
barryj said:
I am a tutor)
Then you understand the need for an accurate drawing and a well-stated question.
Well, the drawing must be accurate because my 15 year old student worked the problem in about 15 seconds. Go figure.
No, he depends on lucky guesses by some students. Obviously you are just not intuitive enough :smile:
The drawing was accurate. As it turns out, what looks to be a right angle is in fact about 83 degrees.
No, the student knew the theorem, applied it, and got the correct answer. There was no lucky guess here. How could anyone look at that diagram and guess the answer to be 12?? If they could then they would be good at gambling, stock market, and other guessing games. The surprise here is that the people responding here seem to not know their geometry, as I did not know the theorem until I researched it.
Not so much.
Another reason to draw an accurate picture is that it's the first step in solving the problem. You learn about the elements and relationships when trying to draw it. This angle needs to be acute, that angle needs to be obtuse, this line segment has to be shorter than that line segment, etc.
While I agree "these lines look congruent" is not a proof, but that does not mean that any random grouping of lines makes a good drawing.
Vanadium 50 said:
Not so much.
So, you are saying that when solving a geometry problem I should get out my calipers and draw the diagram with precision?? No way. A general diagram is all that is necessary.
The point is that from the begining you don't know what that angle is, so why draw it so close to a right angle!
I
If you knew the theorem then it would not matter if the angle was close to a right angle or not. The surprising fact is that the "experts" here did not know the theorem otherwise they would have merely refreshed my memory of it.
Well, yes, it certainly is true that if you know the answer in advance then a correctly drawn figure has less relevance, it's just an annoyance.
The answer was not known in advance. One had to use the knowledge of the theorem to get the answer. The angle could be drawn as a right angle, an acute angle, or an obtuse angle. It would not make any difference in the solution.
law of sines works. 4 and 6 are opposite same size angles. 8 and x are opposite a pair of supplementary angles, which have the same sine.
barryj said:
So, you are saying
Don't put words in my mouth. It';s the cheapest form of debate.
My major pointy is that if you want help, you should make it easy for them to help you. Careless diagrams don't do that. My minor point is that a good drawing is the starting point of a good solution. You may sneer at this, but a) that doesn't make it any less true, and b) you are the one asking for help after all.
Actually, it was not my diagram. I copied it out of a geometry textbook.
When I posted the diagram, I did not know if it was a right triangle or not.
  • · Replies 31 ·
  • · Replies 38 ·
