What guarantees the electron mass
  • Context: Graduate
  • Thread starter Thread starter semc
    Electron Mass
The mass of electrons and positrons in pair production is an intrinsic property, defined by their fundamental nature. Both particles possess the same mass and opposite charge due to CPT symmetry, which dictates that their charge-to-mass ratios are identical. Current theories do not provide a definitive prediction for the mass of electrons, which is primarily determined through experimental measurement. Any deviation in mass would classify the particle as a different entity, such as a muon.
  • Understanding of fundamental particle physics
  • Familiarity with CPT symmetry
  • Knowledge of experimental measurement techniques in particle physics
  • Basic concepts of particle classification (e.g., electrons, muons)
  • Research the principles of CPT symmetry in particle physics
  • Explore experimental techniques used in bubble chambers for measuring particle properties
  • Study existing theories on fermion mass generation
  • Investigate the classification of particles and their intrinsic properties
Physicists, students of particle physics, and anyone interested in the fundamental properties of matter and the behavior of subatomic particles.
semc
I am just wondering in pair production, what is the physics that determine the mass of the electrons? Why can't the electron get more mass than the positron or the other way round?
This is a bit puzzling. Maybe you should explain why, in a pair production, you think electrons can have variable masses.
Please note that the mass of a bare electron is well-defined. A bare particle, having a mass different than an electron, is no longer an electron. We either call it a muon, or we have discovered a new particle.
Zz.
The mass of fundamental particles is simply an intrinsic property, much like charge and spin.
The mass of the electron is something we measure from experiment. I don't believe there is any good theory for predicting the mass. We observe in bubble chambers and the like that the positron charge to mass ratio is the same as the electron charge to mass ratio. It's possible that there is some small difference in masses, but there's no compelling reason to believe so.
The positron must have the same mass and opposite charge to the electron by CPT symmetry.
There are (incomplete) theories that attempt to explain the masses of the electron and other fermions.
10K
  • · Replies 0 ·
  • · Replies 22 ·
