WHAT HAPPENS IF I HEAT Fe2+ or Mn2+ in air?
  • Thread starter Thread starter Panthera Leo
    Air Heat
Heating Fe2+ or Mn2+ in air at temperatures between 700 to 1000°C results in oxidation, specifically converting FeO to Fe2O3. The equilibrium oxygen partial pressure can be determined using the reaction equation 2Fe2O3 = 4FeO + O2(g), where K_rxn = pO2 / p_total. To control oxidation, flowing an inert gas over a mixture of Fe2O3 and FeO can stabilize the oxygen partial pressure, provided there is a sufficient excess of powder to manage oxygen absorption or release. Additionally, heating CrCl3 in air at 1000°C may lead to sublimation and oxidation reactions, producing Cr2O3 and Cl2.
  • Understanding of thermodynamics and equilibrium reactions
  • Knowledge of oxidation states and their changes during heating
  • Familiarity with inert gas flow techniques in chemical processes
  • Basic chemistry of metal oxides and halides
  • Research the thermodynamics of metal oxidation reactions
  • Learn about controlling oxygen partial pressure in chemical reactions
  • Study the sublimation and oxidation processes of metal halides
  • Explore the kinetics of reactions involving metal oxides at high temperatures
Chemists, materials scientists, and engineers involved in high-temperature processing of metals and their compounds, particularly those focused on oxidation control and reaction kinetics.
Panthera Leo
I am wondering if I heat Fe2+ Or Mn2+ in air at 700 to 1000 C, does their oxidation number change? if yes, how should I avoid this, when heating in a furnace?
Thanks in advance
i assume you mean if heating FeO in air will further oxidize it to Fe2O3? YES it will.
thermodynamics will provide the equilibrium oxygen partial pressure:
one method to pin oxygen partial pressure is to flow an inert gas through a mixture of Fe2O3 and FeO powders, which can set the oxygen partial pressure flowing over your sample. just ensure you have a large excess of powder relative to the number of moles of oxygen that might need to be absorbed or released, and that the powders are held at a temperature where the reaction kinetics are fast (but not so high that the powders sinter and coarsen, else you lose surface area and decrease kinetics)
What about CrCl3 ? will the oxidation number of Cr3+ change under when heating in air at 1000C?
i think you should be worried about other reactions when heating halides in air.
e.g., sublimation/evaporation CrCl3 = CrCl3(g)
oxidation 4CrCl3 + 3O2(g) = 2Cr2O3 + 6Cl2(g)
etc.
  • · Replies 18 ·
