What happens to the position of two attracting charges when a conductor is inserted between them?
  • Thread starter Thread starter Rob2024
    Charges Position
The discussion revolves around the behavior of two attracting charges when a conductor is inserted between them. The subject area includes electrostatics and the method of image charges.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the implications of inserting a conductor, questioning how it affects the forces between the charges. Some discuss the method of image charges and its applicability to different conductor shapes, while others consider the effects of introducing an equipotential surface.
The discussion is active, with participants sharing insights and questioning the validity of assumptions regarding the conductor's shape and its impact on the charges. There is no explicit consensus, but various interpretations and considerations are being explored.
Participants note that the problem is not well-constrained, and assumptions about the conductor's shape and position are under examination. The potential effects of different configurations on the forces experienced by the charges are also discussed.
Rob2024
Two oppositely charged point charges hang from two pendulums and attract each other. A block of neutral conducting metal is placed in between them without touching the charges. Do the two charges move closer to each other or away from each other?
##\frac{k Qq}{r^2}##
I know this question is not constrained too well. Since it's not constrained too well. I thought I could just use a ball conductor, it induces two image charges which would increase the force experienced by either one of the hanging charges. Therefore the answer is that they will move closer to each other. Is this reasoning correct?
A big ”it depends”.
If you introduce a conducting plane exactly in the middle between the charges … nothing will happen. The conductor essentially introduces a forced equipotential surface, but the plane right in between the charges was already an equipotential plane without the sheet so the potential solution - and hence all of the fields - will be exactly the same.
The reasoning with introducing mirror charges is not generally sound. Consider the case where you introduce an infinite conducting plane in the middle betweenthe charges. You now have to solve the Poisson equation in both halves of ##\mathbb R^3## separately - ignoring the charge that is in the other half because it is not part of that solution. Each solution can be performed by extending the problem for the half-space to all of ##\mathbb R^3## and introducing the mirror charge. That mirror charge will be the same magnitude but opposite sign - effectively reproducing the original problem without the conductor.
For your setup with the sphere though (and essentially any setup that does not introduce a conductor along something that is already an equipotential) the original charges will induce a charge redistribution in the conductor such that it becomes an equipotential. This will typically lead to stronger attraction in the system.
kuruman said:
Your reasoning is conceptually sound. Are you familiar with the method of image charges?
I am familiar with image charge. It's what I used in the reasoning since image charge for spherical conductor is well understood.
I don’t think you need to assume any particular shape, but perhaps certain general aspects of it.
If there is a pair equal and opposite charges at the same point in the block such that the negative charge can move closer to the external positive charge at the same time as moving further from the external negative charge then it will do so. It will then exert a greater pull on the former and a reduced push on the latter.
The question is, are the directions of those forces such that the components in the relevant direction have the desired change? For example, consider the block having arms that extend around and close to the other sides of the pendulums.
  • · Replies 35 ·
  • · Replies 17 ·
