What happens when we close the switch?
  • Thread starter Thread starter firefox444
    Switch
This discussion centers on the behavior of light bulbs in a circuit when a switch is closed. The consensus is that when the switch labeled 's' is closed, the four corner bulbs remain lit, while the middle bulb does not light up due to no potential difference across it. The circuit configuration is analyzed, revealing that the four bulbs are treated as parallel resistors when the switch is open and as a series circuit when closed. Ultimately, the middle bulb remains off regardless of the switch's position, confirming the importance of understanding circuit behavior in physics.
  • Understanding of basic electrical circuits
  • Familiarity with series and parallel resistor configurations
  • Knowledge of potential difference and current flow in circuits
  • Basic principles of electric forces and electric fields
  • Study Ohm's Law and its application in circuit analysis
  • Learn about Kirchhoff's circuit laws for complex circuits
  • Explore the concept of equivalent resistance in series and parallel circuits
  • Review electric potential energy and its relation to circuit behavior
This discussion is beneficial for physics students, educators, and anyone interested in understanding electrical circuits and their behavior during different configurations.
firefox444
Hello,
I have a physics midterm on monday and this question is on the study guide so help with this problem would be greatly appreciated.
(ok, since this diagram isn't showing up properly, here is a pdf file that includes the diagram I am asking about http://www-physics.mps.ohio-state.edu/~klaus/f06-112/midterm_options.pdf
_ X X
__ | |
| |-----X-| s|---|
| X X
So What happens when we close the switch (labeled s)? The X marks represent light bulbs. What lights are on/off before closing the switch and what lights are on/off when after we close the switch? Also how would I find the total resistance?
Thank you!:cool:
ok the diagram drawing isn't working...but here is a pdf file with the diagram
The four hot cross buns continue to smoke?
thanks for the reply...but why the question mark? I'm taking from your reply that the four "corner" lamps will light up before closing the switch and they will continue to light up after it is closed...but what about the middle lamp?
Thanks? lol
Thanks? lol
The question mark reads as:
Diagram too ambiguous to understand what's happening. Labels good.
what diagram is too ambiguous? what needs to be clarified? the one in the pdf file should be fine according to the professor?
help? lol
help? lol
The answer depends on the bulbs being used. Since nothing was said to the contrary, I think you should assume they are identical, having some constant resistance R. Figure out how the potential on one side of the branch with the switch compares to the potential on the other side of that branch when the switch is open. How is that going to caange (or will it change) when the switch is closed?
so when the switch is open the four bulbs/resistors should be treated as parallel. (1/sum of left side) + (1/sum of right side) = (1/R total)
and when the switch is closed it should be treated as a series? (sum of left side) + (middle) + (sum of right side).
So the light bulbs on the outside will stay on with or without the switch but the bulb in the middle will only be on if the switch is closed?
correct? :-(
Yes, but since you don't know any of the resistances you cannot find the actual R. What is important here is that the same current flows through the left branch as through the right branch.
No. There is no way to treat this combination as series or parallel
correct? :-(
No. Go back to the first situation and figure out how the potential at a point between the two bulbs on the left compares to the potential at a point between the two bulbs on the right. Then ask yourself how much current will flow if you close the switch.
so when we close the switch the two upper lights remain same voltage but the two lower ones have lower voltage and the middle light has the same voltage as the upper lights? I'm not sure if this makes sense considering "same voltage acorss all elements in parallel" but it's 2 am here...so I'm tired :-(
Let's assume the resistance of each lamp is the same.
I have an exam at 4:30...but i'll probably be w/o internet at 2:30..so i'd really appreciate any last minute advice regarding chapter 18 (electric forces and electric fields), chp 19 (electrical potential energy and electric potential) and chp 20 (electric circuits).
Thank you!
Thank you!
I have no idea what chapters you are talking about, but I will tell you this. There is no potential difference between the points I asked you to compare. When you close the switch nothing happens. The light in the middle remains dark and the others have exactly the same current they had when the switch was open.
Yep. Nothing happens. There's no potential across the middle bulb.
Well, just wanted to stop by and say THANK YOU!
There was a 5 point (out of 100) problem regarding what happens to the midle bulb and I got it correct..not to mention I scored 98/100 on the test which is amazing considering I've never done that well in Physics before. The class average was a 78. Too bad I don't do so well on the weekly quizzes ...so yea...I need to improve on those. Well once again THANK YOU...you guys made by day when I saw your last repies!:cool:
  • · Replies 21 ·
