What is an Eigenstate in Relation to Schrodinger Equation?
  • Context: Undergrad
  • Thread starter Thread starter CookieSalesman
    Eigenstate
15 replies · 4K views
CookieSalesman
What is an eigenstate in relation to the Schrödinger equation?
We've been working with this stuff but I don't exactly understand what that is.
I know of linear algebra eigenstates or eigenfunctions but I don't know if they are directly related.
They are directly related. The set of all eigenstates of a non-degenerate linear operator form a basis for the vector space, which in the Schrödinger case is the vector space of all possible configurations of the system.
In the Schrödinger equation, we can use this basis property to express the initial state as a linear sum of eigenstates of a particular linear operator. The Schrödinger equation then tells us that each of those evolves over time by the scalar multiplier ##e^{ikt}## changing with time ##t##. The scalar multiplier is the 'phase'. Because ##k## differs between different eigenstates, the periods for phase variation vary between eigenstates, so the relative phase changes, which means that the overall state, which is the sum of the individual components, varies over time in a way that is not just a scalar multiplier.
If you're working with the Schrödinger equation, you're probably working with wavefunctions ##\psi(x,t)## or ##\psi(x)##.
If ##\psi## is an eigenstate of an operator, then when you apply the operator to ##\psi##, you get ##\psi## multiplied by a constant (the eigenvalue).
For example, if ##\psi## is an eigenstate of the momentum operator ##-i\hbar \frac {\partial} {\partial x}##, then $$-i\hbar \frac {\partial \psi} {\partial x} = p\psi$$ where ##p## is the eigenvalue, i.e. the momentum of that state.
So more or less, eigenstates are simply solutions?
Yes. They are solutions to the eigenvalue-problem of the operator corresponding to the observable in question.
Not really. Energy Eigenstates are solutions to the time independent Schrödinger equation, each for a corresponding energy value.
But, more generally, any linear operator has its eigenstates. It is an assumption in QM that any operator that represents an observable has a complete set of orthogonal eigenstates. The Hamiltonian being a specific example of this.
Other operators may have eigenstates with different properties. The raising and lowering operators of the harmonic oscillator are good examples. The eigenstates of the lowering operator are the so-called coherent states. And the raising operator has no eigenstates.
PS eigenstates relate directly to linear operators are are really only indirectly related the Schrödinger equation itself.
Ok but it seems like you just said eigenstates are solutions. YOu said that any linear operator has its eigenstates so those eigenstates are simply "solutions" corresponding to specific quantum numbers right?
Nothing is a "solution". Things are solutions to specific equations.
Energy eigenstates are solutions to the time independent Schrödinger equation.
Energy eigenstates are not solutions to the full Schrödinger equation. For that you need to include a function of time, related to the energy.
An eigenstate of a linear operator is well defined without any reference whatsoever to the Schrödinger equation or to QM for that matter. It is defined as a solution to the eigenvalue equation for that operator.
To make this more explicit, the operator in question here is the Hamiltonian operator: $$\hat H = -\frac {\hbar^2} {2m} \frac {\partial^2} { \partial x^2} + V(x)$$ Written in the form of an eigenvalue equation, the Schrödinger equation is ##\hat H \psi = E \psi##.
PeroK said:
[...] But, more generally, any linear operator has its eigenstates. [...] And the raising operator has no eigenstates.[...]
This is a self-contradiction. Can you, please, re-phrase your opinion?
I think the sentence just inadvertently lacks the word 'Hermitian'. Any Hermitian operator has a complete basis of eigenstates. The raising operator is not Hermitian.
Any linear operator has a set of eigenstates. That set may be empty.
Yes, the raising operator is not Hermitean, but this doesn't mean it has no eigenstates.
Sure, I didn't say it did. But with the insertion of 'Hermitian' in the post, it is not self-contradictory, which is what was being discussed.
Alright, putting "hermitean" there is a step forward as the first statement is rephrased. The raising operator has eigenstates, it's then the second statement of the two I quoted that is wrong.
