srinaath
- 51
- 2
I am an electrical guy, i can't understand the concept of constant flow system...and how temperature is controlled in room by Air conditioner...thanks
The discussion focuses on the concept of constant flow systems in HVAC, specifically how they control temperature and humidity. Key methods include cycling the fan based on thermostat settings, modulating the refrigerant circuit or chilled water valve to adjust supply air temperature, and utilizing reheat systems to maintain room temperature while ensuring adequate dehumidification. The conversation highlights the importance of understanding these mechanisms for effective HVAC system control.
PREREQUISITESElectrical engineers transitioning to HVAC roles, HVAC technicians, and anyone involved in the design or control of air conditioning systems will benefit from this discussion.
russ_watters said:Welcome to PF!
Your question is very vague: there are several types of constant flow systems, which can control temperature in several different ways:
1. By cycling the fan.
2. By controlling the amount of cooling done to the supply air.
3. By adding reheat.
Do you have a more specific description of the system you are dealing with?
I'm not sure what "classified" means...srinaath said:i am new to HVAC, can you tell me the types of constant flow system and why they are classified like that?? and can you elaborate the temperature control in each ways!...
1.How fans control the temperature because fans are just responsible for air flow ?? (sorry that i ask so basic questions!)russ_watters said:I'm not sure what "classified" means...
1. Cycling is just what it means: the fan turns on and off based on a thermostat. Most residential systems work that way.
2. Controlling the amount of cooling done to the supply air is via cycling/modulating a refrigerant circuit or modulating a chilled water valve. That changes the supply air temperature. The downside to this is you don't get good dehumidification that way, so you need a separate method of dehumidification.
3. Reheat uses an electric or hot water heating coil to heat the air back up to maintain the temperature of the room after cooling it enough to ensure adequate dehumidification.
You may start with google. Search HVAC then have plenty of time to read, then come back to the forum, when you have done your part (study)srinaath said:i am new to HVAC, can you tell me the types of constant flow system and why they are classified like that?? and can you elaborate the temperature control in each ways!...THANK YOU SO MUCH...
ya i did some ground work by searching in google...but am not getting the clear picture...can you suggest me some books about basics of air conditioningRonie Bayron said:You may start with google. Search HVAC then have plenty of time to read, then come back to the forum, when you have done your part (study)
Click this HVACsrinaath said:ya i did some ground work by searching in google...but am not getting the clear picture...can you suggest me some books about basics of air conditioning
Yes, this is getting to be a pretty huge information request. You're basically asking us to write a book for you!Ronie Bayron said:You may start with google. Search HVAC then have plenty of time to read, then come back to the forum, when you have done your part (study)
russ_watters said:Yes, this is getting to be a pretty huge information request. You're basically asking us to write a book for you!
Is there a specific reason or problem behind this question that might help us focus it a little better?
Amazon has a lot of books. Here's one that might help:
https://www.amazon.com/dp/1619601990/?tag=pfamazon01-20
But again, without knowing the specific reason/focus of these questions, it is tough even to recommend the right book!
That's a difficult/unfair position you have been put in. Designing the controls for an HVAC system is the job of a mechanical engineer. It will take years of study and experience to turn you from an electrical engineer into a functional mechanical engineer.srinaath said:hi, thanks for your advice , actually am an electrical engineer, recently working on HVAC systems... my role is to control the HVAC system...
When air gets cold, the moisture in it condenses out. It's what happens on the outside of a cold drink. That's the sole method of dehumidification of virtually all standard/general purpose HVAC systems.But i have doubt regarding humidification/de-humidification ( i have some knowledge about humdistat)..."In an ‘All-Air system’, the refrigerant or chilled water is used to cool and dehumidify the air in the air handling unit (AHU).(Source:http://www.electrical-knowhow.com/2012/03/in-previous-air-conditioning-system.html) i can't understand this statement...like how will refrigerant used to de humidify the air..
A humidistat is a controller - it doesn't do anything besides turning the de-humidifier on and off or modulating it. It isn't a de-humidifier itself. About the only other method of dehumidification used is absorbing the moisture with a desiccant....is there any other method for humidify/de humidify (other than humidstat)...
