Mentor
- 50,919
- 26,947
In cars, I don't think so; the low pressure cutoff is enough. When it's cold enough outside, the pressure of the refrigerant never gets higher than the low pressure cutoff, so the compressor won't run even if the A/C switch inside the car is turned on.sophiecentaur said:Maybe there is a safety circuit to inhibit the compressor from running till the temperature is safe.
The problem with having an outside temperature sensor controlling this in a car is that such sensors can be skewed by the heat sources in the car itself, the main one being the engine, and by not having a good place available to sense undisturbed outside air.
