LaTeX What is the LaTeX code for large brackets and parentheses?
  • Thread starter Thread starter askor
    Code Latex
The discussion focuses on the LaTeX code for creating large brackets and parentheses, as well as using subscripts and superscripts. To achieve larger parentheses, the command "\left( ... \right)" is recommended, which automatically adjusts the size based on the content. For square brackets and curly brackets, the commands are "\left[ ... \right]" and "\left\{ ... \right\}", respectively. It is emphasized that each "\left" must be paired with a corresponding "\right", and blank symbols can be used with "\left." and "\right." to create unmatched pairs. For further details on LaTeX formatting, users are directed to resources like the Physics Forums help page and Wikibooks.
askor
What is the latex code used in this forum of large bracket (and parenthesis) and subscript and superscript?
For example, the below parenthesis is too small:
##(x1 + \frac{1}{\frac{1}{x1}})##
\left( x_1 +\dfrac{1}{\frac{1}{x_{1}}} \right)
##\left( x_1 +\dfrac{1}{\frac{1}{x_{1}}} \right)##
What about the large bracket?
What is the latex code of large bracket?
fresh_42 said:
\left( ... \right)
Use "\left( ... \right)" for large parentheses, "\left[ ... \right]" for large square brackets, "\left\{ ... \right\}" for large curly brackets, "\left. F(x) \right|_a^b" if you want
$$\left. F(x) \right|_a^b $$
The left and right objects need not match, but every "\left" command must be followed by a "\right" command, possibly for a blank symbol, like this: "\left( ... \right." The commands "\left. " and "\right." insert blank symbols, as in (1) above. Note that those are "\left_dot = \left.", not "\left_blank_space = \left ".
The size of the brackets are automatically adjusted to match the contents of the brackets.
Likes DrClaude
  • · Replies 16 ·
