What is mass fundamentally, beyond its effects?
  • Level: Undergrad
  • Thread starter Thread starter yhPscis
    Mass Mystery
95 replies · 13K views
The quantity of matter confined in a (finite) space region?
DrStupid said:
example
OK, than let me falsify your claim with a modification of Newton's laws that work with Galilean transformation:
The first law remains unchanged.
The second law shall define force as
[itex]F := \dot p \cdot \left( {1 + \frac{{v^2 }}{{c^2 }}} \right)[/itex]
In order to keep momentum conserved the third law need to be adjusted accordingly:
[itex]F_2 = - F_1 \cdot \frac{{c^2 + v_2^2 }}{{c^2 + v_1^2 }}[/itex]
That also applies to all natural laws dealing with forces, e.g. Newton's law of gravitation:
[itex]F_g = G \cdot M \cdot m \cdot \frac{r}{{\left| r \right|^3 }} \cdot \left( {1 + \frac{{v^2 }}{{c^2 }}} \right)[/itex]
These laws of motion are independent from the frame of the observer and within the limits of classical mechanics they describe all observations correctly because the resulting equations of motions are identical with the results of Newton's original laws. But the modified force is neither proportional to acceleration nor frame independent. This counter example clearly shows that you are wrong.
If you start with your premise that force is frame dependent, you are immediately in conflict with Galilean relativity. You are saying that a standard force unit (e.g a standard compression distance of a standard spring) depends on the frame of reference. That would violate the premise that distance is the same in all reference frames. All I am saying is that a standard force unit will be observed to accelerate a standard mass unit at the same rate in all inertial frames (non-relativistic).
Besides, it appears to me that all you are saying with your example is that Galilean relativity would be observed to be correct for frames moving at non-relativistic relative speeds, and that at such speeds ##F=\dot{p}## would be observed, to within a negligible margin of error.
AM
No, I'm not. Please refer to my counter example above. With these modifications of the laws of motion force would be frame dependent without violating Galilean relativity.
No, I would say that this wouldn't be an appropriate standard force unit.
No, you are saying that
Andrew Mason said:
F=ma follows from Galilean relativity and the first law.
I will no longer spend any effort into the falsification of your claims because it is not my duty and it seems that it doesn't stop you from repeating them. You are responsible for proper justification. So please show me step by step how you get F=m·a from Galilean relativity and the first law.
That depends on the value of the universal constant c. It does not need to be the speed of light. With c=1m/s the difference between the original and the modified second law would be obvious even at walking speed.
The first law of motion (which is part of Galilean Relativity) says, in part, that a force applied to a body at rest will change that body's motion (ie. the body will experience a change in motion relative to its initial rest frame). And it says that all inertial reference frames are equivalent: the laws of motion are the same in all inertial reference frames.
So according to Galilean Relativity, the same physical interaction between two unit bodies will have the same result in all inertial frames of reference. Let's say that a standard interaction is the collision of two 1 kg steel balls, Ball A which is unconstrained and stationary, and Ball B which is moving at one unit of velocity in the rest frame of Ball A. Ball B is moving toward ball A at one unit of velocity immediately before it collides with Ball A. Galilean Relativity says that Ball A will experience the same change in motion whether the interaction takes place on a uniformly moving rail car or on a stopped rail car. If it did not, one would be able to differentiate between inertial reference frames, thereby destroying the basic postulate of Galilean Relativity.
The equivalence of inertial reference frames means that the graph of velocity vs time experienced by Ball A during the collision as measured in the frame of the rail car would be the same regardless of the (uniform) velocity of the rail car. Galilean Relativity also postulates that time and distance are the same in all inertial reference frames This means that the resulting change in velocity would be observed to be the same in all inertial reference frames. (This is just a matter of applying the Galilean transformation to the experiment).
I think we would both agree to this point. But if I am mistaken, let me know where we differ.
Now, let's involve the concept of force. By the First Law we know that Ball A experiences a force because it changes its motion. So let's attach a spring to Ball A and have Ball B move toward that spring at unit velocity and have a high speed camera record the interaction so we can measure the compression of the spring as a function of time.
Since the interaction is the same in all reference frames, the graph of spring compression vs. time will be the same regardless of how fast the rail car is uniformly moving. And since time and distance are the same for all inertial reference frames, the compression distance as a function of time will be the same for all inertial observers, regardless of how fast they are moving. So the area under that graph would be the same for all inertial observers. Since motion change when the spring compresses, we will say that the compression of the spring represents a force. We won't assume Hooke's law. We will just say that a force, F, at a given time is represented by the compression distance. The area under the graph is proportional to the impulse received by Ball A.
This shows that the impulse, ##I=\int Fdt## on Ball A is the same for all inertial observers. And since time is the same for all inertial observers, the time averaged force is the same. So let ##I = \int Fdt = F_{avg}\Delta t##.
Now repeat the experiment with two unit balls, Ball A and Ball A', each undergoing simultaneous collisions with unit ball traveling at unit velocity. The change in motion of Ball A will be identical to the change in motion of Ball A'. So the change in momentum (product of no. of unit balls and velocity) is double. And, however you want to define force, the average force is doubled. And since the mass has doubled with the same change in velocity, momentum change has doubled.
Since the change in velocity of Ball A, ##\Delta v##, is the same in all frames, this means that the average force, ##F_{avg}## multiplied by the time, is proportional to the change in momentum: ##F_{avg}\Delta t \propto m\Delta v \rightarrow F \propto \dot{p}##.
You could also do the same experiment using a series of collisions, with the successive collisions taking place with a Ball B traveling at unit velocity with respect to the rest frame of Ball A moving at ##v_i + \Delta v##. You can see in that case that doubling the duration of the same average force doubles the change in momentum. And since ##\Delta t## is doubled and the force is the same, ##2\Delta v/2\Delta t = \Delta v/\Delta t## is constant . Take any number of successive standard collisions and you can see that ##n\Delta v/n\Delta t = \Delta v/\Delta t## is constant. (ie. acceleration is constant)
Now if you take the limit as mass/time/unit velocity approach 0, you can see that a series of the same collisions, or any number of simultaneous collisions or any combination of these, has the same result: ##Fdt \propto mdv##. So if the force is constant over time, dp/dt is constant. And if mass increases proportionally with force, the change in velocity per unit of time is the same.
And that is just Newton's second law.
So why don't you suggest a standard force unit. One does not have to assume Hooke's law, as the above shows.
It would have to be something that can be considered constant over time and space in some reference frame. Your definition of force as ##F=\dot{p}(1+v^2/c^2)## makes it impossible to have such a constant force. So a spring maintained at the same compression distance and applied to a free body would experience a different force depending on the speed of the inertial reference frame in which the spring is situated. I am not sure why you would want to presume that the force changes when nothing observable changes.
See above.AM
"Matter" and "mass" are two different things.
lightarrow
Andrew Mason said:
I did not define force to be mass x acceleration. I just said that f=ma follows from the principle of Galilean Relativity and its premises.
Then I don't understand anything. In post #41 you wrote:
"It is not exactly my definition. Work is defined in terms of force (mass x acceleration) and distance. If you have a better one, you should enlighten us."
This and other statements you did made me think you define force as dp/dt or as m*a. Which is instead the definition of force you give?
lightarrow
Why?
DrStupid said:
Why?
It isn't really necessary. I just wanted to say that since all frames are equal, and the spring is compressed the same way for the same duration in all reference frames, Body A is subjected to the same time average force in all frames. Imagining a plot of compression vs. time simply helps one see that. The absolute symmetry of Galilean Relativity means that the forces must be the same for all identical time intervals for all inertial observers.
AM
lightarrow
Yes, but not in classical mechanics. Newton's definition of mass as "quantity of matter" applies to classical mechanics.
AM
lightarrow
I said work is defined as force x distance and Force = mass x acceleration. I am not defining force as mass x acceleration. All I said was that F=ma follows from Galilean Relativity.
AM
Of course it is necessary to conclude
With my modified laws of motion above this is not the case. As I already mentioned all affected laws of nature would (of course) need to be adjusted accordingly. This also applies to Hooke's law. It would turn into
[itex]F = k \cdot \Delta x \cdot \left( {1 + \frac{{v^2 }}{{c^2 }}} \right)[/itex]
resulting in the frame-dependent Impulse
[itex]\int {F\left( t \right) \cdot dt} = k \cdot \int {\Delta x\left( t \right) \cdot \left[ {1 + \frac{{v\left( t \right)^2 }}{{c^2 }}} \right] \cdot dt}[/itex]
But the modified laws of motion and the corresponding Hooke's law would still be the same in all frames of reference and the resulting equations of motion are identical with the good old classical mechanics. Thus your assumption about force and compression of the spring does not result from Galilean relativity and/or the first law. You must explain where it comes from.
DrStupid said:
Of course it is necessary to concludeWith my modified laws of motion above this is not the case. As I already mentioned all affected laws of nature would (of course) need to be adjusted accordingly. This also applies to Hooke's law. It would turn into
Ok. But you are making some kind of fundamental distinction between the observed interactions based not on what is observed but only on the velocity of the frame of reference. So not all frames of reference are equivalent. I am just saying that without defining force in any way, the same interaction applied successively to the same body causes constant acceleration, and the same interaction applied to any number of identical bodies simultaneously results in the same change in motion to each. So any combination of these successive and simultaneous interactions has the result that ##Impulse = \int Fdt \propto \int dp = \Delta p## which is just Newton's second law.
It comes from symmetry and the equivalence of inertial frames of reference. There is no basis for having different effects of the same spring compressed the same distance applied the same way to the same mass but in different inertial frames.
The equations of the natural laws result from observations. Why else should I need to adjust them to the modified laws of motion? This is necessary to keep the results in agreement with experimental observations.
That wouldn't even follow from a simple distinction on the basis of velocity. The kinetic energy of a body with constant mass also depends on it's velocity only but that doesn't mean that there are preferred inertial frames.
You still need to explain how this results from Galilean relativity and the first law.
I'm not talking about different effects but about different forces.
Exactly. All I am doing is saying that if two interactions are identical, they are identical in all inertial frames of reference under Galilean Relativity. If they produced a different change in motion of the same unit body in the same unit time period depending on the inertial reference frame in which it is observed, the premise of Galilean Relativity is violated. You are using a different concept of force. So let me ask you: what is the basis for saying that a unit mass on a uniformly moving rail car subjected to the same interaction as an identical unit mass sitting on a stationary rail car, is subjected to a different change in motion?
But kinetic energy being constant in all reference frames is not a law of motion. Kinetic energy of a body is defined by motion relative to an arbitrary frame of reference. Change in motion of a body is always with respect to a particular inertial frame of reference of the body prior to the change.
I have done that in my post #64
All I am saying is that since the same interaction between the same bodies produces the same changes in motion in all reference frames, there is no basis for distinguishing between the forces that apply during those identical interactions. Force is defined in the first law as a physical phenomenon that causes a body to change its motion. I am not sure why you want to say that the same phenomenon that has the same effect on identical bodies in all reference frames should be called a different "force".
AM
No, that's not all you are saying. You also say that the corresponding forces are identical and that this is not just the result of a definition but a consequence of Galilean relativity and the first law.
I don't know why somebody should say something like that.
And with my modification of the second law force is also defined by motion relative to an arbitrary frame of reference (among other things). If kinetic energy does not define a preferred frame of reference why should that be a problem in case of my definition of force?
No, you didn't because you didn't explain why "a force, F, at a given time is represented by the compression distance". Your argumentation is broken without this explanation.
No, you are saying that F=m·a follows from Galilean relativity and the first law. That implies that distinguishing between the forces that apply during those identical interactions is not only unmotivated but forbidden.
Just to disprove your claim that Galilean relativity and the first law results in F=m·a.
Did the OP ask "what is mass" or "what Newton thought mass is"?
Actually with "quantity of matter" we usually mean "number of moles", nowadays.
lightarrow
Isn't that amount of substance?
Yes, I have just controlled, you're right, I remembered wrong.
lightarrow
Anyway, saying "mass is the quantity of matter" doesn't answer much to the question "what is mass?", unless someone defines "matter" in terms of something measurable.
lightarrow
Well, one does have to have a concept of what a force is. And I say that this concept of force comes from the first law: the physical phenomenon that causes a body to change its motion.
So now we want to compare forces. So in IFR A, the same physical interaction applied to each of two identical unit bodies at the same time for the same duration would result in the same change of velocity. If that was not the case, then after the interaction ended (at the same time for both unit bodies), the bodies would define two different inertial frames of reference in which either: 1. the laws of motion were not the same for each body, or 2. time and space were measured differently for each body.
Then it is just a matter of equating this concept of "interaction" (ie. that which causes a body to change its motion) to the concept of force by virtue of the first law. So we define a standard interaction of some kind and call it a unit of force.
Now we translate to IFR B which is moving at velocity v relative to IFR A. In the reference frame of IFR B, we can say that based on the equivalence of IFRs (a premise of Galilean Relativity), one unit of force applied to each of two identical unit bodies at the same time for the same duration would result in the same change of velocity and that this change in velocity would be the same change of velocity as observed in IFR A. If that was not the case, we could easily distinguish between IFRs.
If you disagree, please explain why this would not be the case yet Galilean Relativity would not be violated.
So you would appear to agree that the same change in motion results from the same interaction. All I am doing is assigning the concept of "average force" to the interaction for its duration, because it is an interaction that results in a change in motion. What is your concept of force?
Because the laws of motion have to be the same in all IFRs and the first law of motion says that a force is something that causes a change in motion of a body that was, before being subjected to the force, either at rest or in uniform motion. You appear to want to define force as something else. All I am saying is that if all IFRs are equivalent, then the same "force" for the same duration will cause the same change in motion to the same body in all IFRs.
Using your suggestion, ##F = \dot{p}(1-v^2/c^2)##, a force, F, applied for a duration ##\Delta t## in IFR A (v=0) to a unit mass would result in a change of velocity of ##\Delta v## (i.e. ##F\Delta t = \Delta v##) but in IFR B (v=vB) ##F\Delta t = \Delta v(1-v_B^2/c^2) < \Delta v##
You don't need the spring. You just need the collision. The spring just allows you to see the collision dynamics better. If two identical bodies subjected to the same spring with the same compression for the same duration had different changes in motion depending only the IFR they were in, then the premise of Galilean relativity would not hold.
I am really saying that Galilean Relativity and Newton's Second Law, together with the underlying premises that time, mass and space are absolute, are equivalent. The second law leads to the equivalence of all IFRs. The equivalence of all IFRs leads to the second law.
I have lost you there. If the interactions are identical, and this is an interaction involving forces, then what basis is there for saying that the forces would be different?
AM
lightarrow
Newton conceived that all matter was comprised of the same fundamental units of matter. That was a guess. But it was an amazingly accurate guess. We now know that the difference in mass of two bodies of matter is very closely approximated by the difference in the number of nucleons each contain. So just imagine the "quantity of matter" to be the "number of nucleons".
AM
So he was quite right even about it, interesting. But, aren't you a Newton's descending? You seem to praise him a lot :smile:
lightarrow
In that case F=ma for constant mass would not result from Galilean relativity and the first law but from Galilean relativity, the first law and the definition above. But if you already admit that an additional definition is necessary, why not simply define F=dp/dt instead? You wouldn't need additional derivations and it would also work for systems with variable mass.
No, that's not all you are doing. You also claimed that F=ma results from Galilean relativity and the first law. But with your statement above you seem to distance yourself from this claim and start to realize that it is in fact the result of an useful but nevertheless arbitrary definition.
I usually use Newton's concept of force as defined by his second and third law of motion. But that does not mean that this is the only possible definition. It is just the definition that has been finally established.
As this applies to the modified laws of motion above I still do not see the problem.
It is not sufficient to say that. You need to justify this claim.
Than try to finish your argumentation without the spring.
That's actually not all you are saying.
That's the wrong question. The correct question is: What prevents me from saying it? F=ma cannot result from Galilean relativity and the first law if I can simply define something else (no matter why) without violating these conditions.
The modern concept of atoms and elementary particles dates back to Robert Boyle's idea of basic particles from 1661. As Newton was not only a Physicist but also an Alchemist it is very likely that he was aware of this idea when he wrote the Principia in 1686. It would still be a guess but not necessarily Newton's guess.
It is not arbitrary to assign the concept of force to dp/dt. One could say that f=dp/dt is a natural definition because it corresponds to reality.If a body is being pulled by a spring with a constant extension then ##\Delta p \propto \Delta t##. I think we agree that this is a true statement within the limits of classical mechanics.
We could do a bunch of experiments and observe that ##\Delta p \propto \Delta t## is constant for any constant spring extension and any mass of body. From this we could deduce that the experiment would give the same result in all inertial frames of reference.
OR: (which is what I am saying) we could start with the a priori rule that all the laws of motion will be the same in all inertial frames of reference and predict that ##\Delta p \propto \Delta t## must be true (i.e. without actually observing it) for any spring extension and any mass of body. If this was not the case then we could use the spring to distinguish between different inertial frames.
AM
And if in frame1 and in frame2 you would observe, e.g., that ##\Delta p \propto \Delta t^2##, what would you deduce?
lightarrow
My modified definition corresponds to reality as well.
Andrew Mason said:
OR: (which is what I am saying) [...]
No, that is not what you are saying. You made a claim about force and not just about the principle of relativity.
lightarrow
One could conclude that the premises of Galilean relativity are incorrect.
This is because the application of the spring for the period ##2\Delta t## to a body at rest in IFR A is equivalent to:
1. applying the spring in IFR A for ##\Delta t## at which time the body is moving at velocity vA, and then
2. re-applying the spring for ##\Delta t##, in which case the body starts the second application at rest in IFR A', (which is moving at vA relative to IFR A) and ends up moving at velocity vA relative to IFR A'
If ##\Delta p \propto \Delta t^2##, the total ##\Delta p = 4v_A## if the application of the spring is viewed entirely in IFR A. But if you look at it as two successive applications of the spring for the same total duration the final velocity relative to A' would be ##v_A##, so relative to A it would be ##2v_A## i.e. ##\Delta p = 2v_A## in A'.
AM
So explain to me how ##\Delta p \propto \Delta t## if ##\Delta p = F\Delta t/(1-v^2/c^2)##.
You would have to say that force magically varies as ##(1-v^2/c^2)## , despite there being a complete lack of physical change to the thing that is causing the force. That sounds a bit like the attempts by Fitzgerald and Lorentz to preserve the concept of ether while explaining the results of the Michelson-Morley experiment.
I see that you are reluctant to concede a natural concept of force. I thought there was an obvious way to think of a force but you can define force however you wish. So we won't even refer to force. We can just refer to springs applied to bodies while maintaining constant extensions or compressions.
I will just say that for applications of springs to bodies while maintaining constant extensions the relationship of ##\Delta p \propto \Delta t## can be predicted from Galilean Relativity. I will not go so far as to say that f = dp/dt can be determined because that depends on what you mean by f.
AM
Mass is energy. Most of it comes from the interactions between gluons and quarks IN subatomic particles.The rest comes from matter interacting with the higgs field.
This is off topic but good to know
Massless particles CAN ONLY travel at light speed and can NEVER slow down.We(have mass) can move at any speed we want, but not the speed of light.
